The Modern Ford Heater-Old Advertising
Posted: Thu Jan 21, 2021 8:07 am
by Herb Iffrig
Anyone ever hear of this?
Re: The Modern Ford Heater-Old Advertising
Posted: Thu Jan 21, 2021 8:26 am
by StevenS
Yes, I actually have one that I got off Ebay about four years ago.
Posted: Thu Jan 21, 2021 3:33 pm
by vech
Herb
I have that exact heater on my 1922 coupe. It works very well.... Almost too well! It will cook you in 40- 50 degree weather. I the summer, the "valve" won't cut the flow of hot air off, so I made a cap on the lathe to plug the end in the passenger compartment, to keep from being roasted. That helped a lot.
A word to the wise. If you find and install any sort of manifold heater, buy yourself battery powered portable a carbon monoxide meter. If you have a manifold leak, you will poison yourself at a stop light. Not so much when you are moving. The CO level will climb real fast iding at a stop light if you have any sort of leak.
- Screenshot_2021-01-21_14-24-13.png (505.24 KiB) Viewed 1940 times
Posted: Thu Jan 21, 2021 3:51 pm
If you have a closed car it is always best to have a window cracked when driving, regardless if you have a heater. They are prone to get exhaust and or blow by into the cab.
Posted: Thu Jan 21, 2021 4:14 pm
Mine doesn't Norm !
Posted: Thu Jan 21, 2021 9:56 pm
by Herb Iffrig
Thank you for the comments.
