Ultrasonic vs Vibratory Cleaner
Topic author - Posts: 184
- Last Name: Schwab
Thinking of getting one or the other. Which one do you find most useful? What are both best used for? What media do you use? Since my use would be limited , how do the Harbor Freight units hold up for hobby use? Thanks, Dave
- First Name: Mack
- Last Name: Cole
- MTFCA Number: 28146
Re: Ultrasonic vs Vibratory Cleaner
I use the larger ultra sonic cleaner from harbor frieght to clean carbs with. Get the 2 year warrenty and use it all you want to.The 1 I am useing now in the shop is my second 1 and it has lasted 3 years or more but is coming apart at the seams. But I use it average 4 to 6 times a week. I want a bigger 1. think about the largest item you want to clean and buy what will take it in. There are some good 1's on Ebay of bigger size for around 150 I think.
- First Name: Jason
- Last Name: Given
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster, 25/26 speeder
I do not have an ultrasonic cleaner (yet).
I have a rock tumbler, with some type of media for de-rusting parts. Both bought from HF. It works quite well, but it takes days and days to work. When the parts come out they are very dusty. I primarily use it for bolts and the like.
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
I have used both. Ultrasonic is great for blind holes and close fitting parts like a clock or pen. A tumbler is great for larger holes and a lot of exposed serfaces like nuts, bolts, ammo shell casings. Both take time and are limited to small things. Most car parts I use either electrolosis or sandblasting.
