27 Coupe Steering Column
Posted: Sun Jan 24, 2021 7:49 am
by mytractor
Hello;
I am working on a 27 coupe and am wondering if anyone can supply a picture of how the lower steering column bracket mounts to the firewall. Not sure if the separate bracket or lower bracket piece mounts to the inside of the firewall or to the engine side of the firewall.
Thanks Steve
Re: 27 Coupe Steering Column
Posted: Sun Jan 24, 2021 11:10 am
by John Codman
On my '27 touring car the lower bracket bolts to the inside of the firewall. I can't see any reason why a coupe would be different. The touring car doors are small and it's possible for one person to hold the screws and install the nuts and washers on the engine side. The coupe will have more substantial doors. It most likely will be easier to have a helper catch and hold the nuts.
Posted: Sun Jan 24, 2021 11:25 am
Mounts to engine side of the firewall;
http://www.mtfca.com/discus/messages/50 ... 1226597205
With the floor boards out you might be able to reach under and hold the bolts.
Posted: Sun Jan 24, 2021 11:42 am
The lower bracket should fit to the outside of the firewall. That way the angled flange on the lower edge aligns with the lower firewall edge on the Inside of the firewall.
That is where the top floorboard rests. The bracket is offset to align the steering column flush with the firewall.
Factory original Nov. '25 production, un-disturbed, prior to restoring.
Posted: Sun Jan 24, 2021 12:07 pm
by Humblej
My 1926 coupe. Different looking bracket, same mounting.
Posted: Mon Jan 25, 2021 11:49 am
by mytractor
Thanks for the information
