				23 T timing cover
				Posted: Sun Jan 24, 2021 9:38 pm
				by tommyleea
				Getting ready to reinstall my timing cover.  From what I have read, if I get the new style seal instead of the felt or rope seal, I don't need the brass shield.  Is this correct?  And, if I get the new style seal, do I center the cover prior to installing the seal?  Thanks.  Tommy
				Re: 23 T timing cover
				Posted: Sun Jan 24, 2021 9:48 pm
				With modern neoprene seal, no brass shield is needed, there is no felt to protect.
Yes, you can place seal in plate first and then center the front plate , or add seal later to cam shaft.
				Posted: Sun Jan 24, 2021 10:11 pm
				by Mopar_man
				I used the new seal.  I put the timing cover on first with the bolts loose, then the seal, then used the alignment tool.  Once it was all lined up I tightened the bolts and then added a bit of Permatex between the seal and the cover.  Let it sit overnight and that's it.  Make sure you check the alignment one more time once everything sets up.  Glad I read this I didn't know you didn't need the big thin washer.
				Posted: Mon Jan 25, 2021 10:28 am
				by tommyleea
				Mopar_man wrote: ↑Sun Jan 24, 2021 10:11 pm
DanTreace wrote: ↑Sun Jan 24, 2021 9:48 pm
Thanks..Pictures help..
				Posted: Mon Jan 25, 2021 11:08 am
				This is a great improvement over the original. I use them in my T ‘s.
And for the purist you can’t see it!
				Posted: Mon Jan 25, 2021 11:15 am
				by tommyleea
				John kuehn wrote: ↑Mon Jan 25, 2021 11:08 am
Good point.
