C crank T block progress!
Posted: Mon Jan 25, 2021 4:56 pm
by Les Schubert
C crank and flathead V8 oil pump
Race grind A cam modified to fit T block
Gear added for the V8 oil pump
Stretched pan (shortened nose). Sump mod
Re: C crank T block progress!
Posted: Tue Jan 26, 2021 7:55 pm
by Weldemup57
Les,
That engine looks great!
What kind of port work have you done to it?
Are there any galling problems running an A cam journal against the T block?
Any idea how much power you'll make?
Thanks,
Posted: Tue Jan 26, 2021 10:14 pm
by Les Schubert
I’ll post a picture of the intake manifold tomorrow.
No problems running the A cam against the block.
The identical engine is capable of pushing a speedster at 100 mph
Posted: Wed Jan 27, 2021 12:31 am
by pete eastwood
On my " C" crank in a " T " block seems like I remember we had to turn down the OD of the counter weights to clear the cam .
Posted: Wed Jan 27, 2021 11:56 am
by Les Schubert
Pete
The counterweights are OK but I had to trim beside the throws for clearance to the camshaft. Now the A camshaft is bigger than a T camshaft and I have filed notches in the camshaft bearing bores
Posted: Wed Jan 27, 2021 1:09 pm
by Les Schubert
This manifold can be mounted either way up to accommodate either a updraft or downdraft
Effectively a 4 intake port manifold. Without the divider the bottom end torque is poor.
Posted: Wed Jan 27, 2021 2:10 pm
by John Warren
Looking Good Les!
Question about the porting, Can you do that without any welding or epoxying , my concern is water the jacket? I know that some epoxy filling can help flow in the intake ports. Thanks for sharing a wild project!!
Posted: Wed Jan 27, 2021 3:00 pm
by Les Schubert
No welding or epoxy!!
Posted: Wed Jan 27, 2021 3:35 pm
by Kevin Pharis
Nice work Les, how much of the manifold is plenum...? And how much is runner...?
Posted: Wed Jan 27, 2021 3:48 pm
by Bud Delong
Wow!! Will the exhaust ports be enlarged?? Bud.
:D
Posted: Wed Jan 27, 2021 4:37 pm
by Dan McEachern
While there is no water around the intake port area, that is not the case with the exhaust ports. The can be opened up slightly but the port walls are not thick enough to open them up significantly.
Posted: Wed Jan 27, 2021 4:49 pm
by Les Schubert
The majority of the intake is runner. Just plenum under the carb.
I have never opened up the exhaust ports.
Posted: Thu Jan 28, 2021 12:22 pm
by John Warren
This Model T kicked my butt in Lincoln Nebraska 2017. I believe that this is his dyno sheet, WOW. It has simmilar porting.
[/size]
Posted: Mon Feb 01, 2021 11:53 am
by Weldemup57
Hey Les,
Is that a pre-26 block?
Do you have a preference for certain year blocks when you modify them?
Thanks,
Posted: Mon Feb 01, 2021 3:20 pm
by Les Schubert
It’s a late style block. I generally prefer for the upper 2 transmission attachment bolts
Posted: Mon Feb 01, 2021 4:14 pm
by Dave Sullivan
Les, did you ever do any research into wet V dry flywheel housing? Seems like a lot of drag to me, but I've never noticed anybody addressing this question. Thank you, Dave in Bellingham
Posted: Mon Feb 01, 2021 8:16 pm
by Les Schubert
I run what I call a “semi dry” flywheel!! There is a dam that keeps the oil away from the flywheel. The transmission shaft is drilled and fed from the rear main bearing. Some oil is sprayed onto the bands.
Posted: Tue Feb 02, 2021 11:15 am
by Dave Sullivan
Thank you, sir, I've been pondering this for some time, thinking of using a dry clutch. Dave in Bellingham
Posted: Tue Feb 02, 2021 5:53 pm
by Les Schubert
Dave
Well if you are planning to use a truly DRY clutch, that is a completely different thing. Assuming that you are not using the T transmission!!
Posted: Thu Feb 04, 2021 8:49 pm
by Weldemup57
Les,
Very interested in how you set-up your semi-dry flywheel .
Any pictures or drawings?
Thanks for your time.
Posted: Thu Feb 04, 2021 9:41 pm
by Les Schubert
I hope this helps
Posted: Sat Feb 06, 2021 11:11 am
by Weldemup57
Les,
I can see how keeping the "T" flywheel from sloshing through too much oil can be a benefit in a race or speedster engine.
I was wondering if you have ever experimented in lightened flywheels for a race/speedster application.
Also would like your opinion on using a "EE" late non-counterweight crank and splash oiling in a modified "T" engine-Will it hold up?
Thanks,
Posted: Sat Feb 06, 2021 2:30 pm
by Les Schubert
As you increase HP you increase bearing load!
Adjusting T bearings is a fact of life with a splash engine. Lack of full flow filtration contributes. Consider that in the ‘30’s the V8 didn’t have shims. Eventually oil filters were added.
So much more HP from a stock oiled T I would expect to do more bottom end “maintenance”!
