? Re safety wire
Posted: Tue Jan 26, 2021 5:19 pm
by DHort
Do you use the same safety wire for the 4th main, the differential, the magneto, and the front radius rod? Is it a special type of wire or can it be purchased at any hardware store? What is the best size? Thank you.
Re: ? Re safety wire
Posted: Tue Jan 26, 2021 5:37 pm
by CudaMan
I bought a spool of 0.032 stainless steel safety wire at a swap meet years ago and use it for everything. I also bought a pair of safety wire pliers at the same swap meet. Not really necessary, but they do make for a neater job.
https://www.youtube.com/watch?v=lsPR9EB4OGo
Posted: Tue Jan 26, 2021 5:40 pm
by walber
I use .041 Stainless, Commonly available at good car parts and/or hardware stores. Not sure if mine came from Napa or Harbor Freight.
Posted: Tue Jan 26, 2021 5:41 pm
by Humblej
I use .041 aircraft grade 302 stainless steel safety wire for the bigger nuts like the wishbone ball studs. Aircraft safety wire spinning pliers do a nice neat job, not necessary, but that is the way I did on aircraft maintenance.
Posted: Tue Jan 26, 2021 9:44 pm
by Oldav8tor
Don't use ordinary wire. You can get aircraft safety wire from a number of sources. I like Aircraft Spruce <
https://www.aircraftspruce.com/search/s ... ety%20wire>
Posted: Wed Jan 27, 2021 7:46 am
20 years or more ago, I went to a farm clearing sale some 250 miles from home. I can't remember what I was chasing, but I can remember a purchase I made.It cost me $1 for 8 or 10 rolls of soft galvanised wire. It had been used, but rolled back up into coils of indeterminate length. It is my go to for any wiring needs, from model T safety wiring to clips for the chookhouse netting. I am down to my second last roll now, but at nearly 75, I reckon I have enough to see me out.
Posted: Thu Jan 28, 2021 2:14 pm
by OilyBill
I use stainless aircraft safety wire for most of what I do. It typically comes in .016, .020, .025, .032, .041. and .057". There is also .020 copper for breakaway use.
Many hardware stores still sell "bailing wire" which is used for bailing hay. It is soft and ductile, easy to bend, and very tough. I keep a roll on hand to hold things together for ease of assembly. It is quite inexpensive, usually $2 -$3 per roll.
I always thought "bailing wire" was a perjorative, until I started using it. Now I know how good it really is.
Posted: Thu Jan 28, 2021 5:34 pm
William, I think your hardware shop sells baling wire for hay bales. Bailing is what you do when your boat is sinking.
Posted: Fri Jan 29, 2021 8:48 am
by Mark Nunn
I was given the remnants of a roll of .035 inch stainless mig weld wire. I haven't had to use it yet or test it for brittleness, though.
Posted: Fri Jan 29, 2021 10:55 am
by Kaiser
Stainless safety wire is annealed, that makes it easier to bend and less prone to breaking after bending. that is the main difference from normal wire or baling wire, also the tensile strength is a little better than other steel wire.
The .032 and .041 sizes are the most common and are both very good for use in your T's innards, because the stainless wire is not magnetic a broken off piece (a rare occasion with safety wire) will not stick to your magneto and do damage where you don't want it.
And yes, a safety wire pliers will make a better and neater job of it.
