Oil Containment
Topic author - Posts: 151
- First Name: Tommy
- Last Name: Russell
Oil Containment
What keeps the oil from spewing out of the valve cover where the throttle rod goes through? 23 T.
- Last Name: Patrick
- MTFCA Number: 50126
Re: Oil Containment
The Model T engine has no pressure. Oil gets to where it needs to go through splashing and there is nothing to splash the oil in the valve stem compartment where the throttle rod goes through, so the oil simply drains out through the hole back to the crankcase. Of course some finds its’ way out through the hole, but not enough for concern. Jim Patrick
- First Name: Tommy
Re: Oil Containment
Thanks..Model T is something else.jiminbartow wrote: ↑Sun Jan 31, 2021 10:14 pmThe Model T engine has no pressure. Oil gets to where it needs to go through splashing and there is nothing to splash the oil in the valve stem compartment where the throttle rod goes through, so the oil simply drains out through the hole back to the crankcase. Of course some finds its’ way out through the hole, but not enough for concern. Jim Patrick
Re: Oil Containment
Yes it is definitely something else. LOL! Originally, the smooth, non-adjustable tappets brought barely any oil at all up into the valve stem compartment, but with adjustable tappets with the hex head tops and adjustable nut, more oil makes it up into the valve stem compartment than did with the smooth sealed tappets, but again, not enough finds its’ way out to cause anymore leakage than was the engine was designed for. Of course when the engine gets hot, you will find that a lot of very fine oil vapor escapes from the valve cover hole and coats the engine and inside the engine compartment. Jim Patrick
PS. One thing I learned the hard way is to NEVER top off the oil when the engine is running, as the fan will blow the oil all over the engine cowl and windshield.
- First Name: Tommy
Re: Oil Containment
Thanks..I still have the old style lifters.jiminbartow wrote: ↑Sun Jan 31, 2021 11:05 pmYes it is definitely something else. LOL! Originally, the smooth, non-adjustable tappets brought barely any oil at all up into the valve stem compartment, but with adjustable tappets with the hex head tops and adjustable nut, more oil makes it up into the valve stem compartment than did with the smooth sealed tappets, but again, not enough finds its’ way out to cause anymore leakage than was the engine was designed for. Of course when the engine gets hot, you will find that a lot of very fine oil vapor escapes from the valve cover hole and coats the engine and inside the engine compartment. Jim Patrick
- First Name: Don
- Last Name: Allen
- MTFCA Number: 50001
Re: Oil Containment
Understatement of the year.
I've come to realize (and become comfortable with the fact) that if my Model T isn't leaking oil....it needs oil.
Any of my other vintage cars, leaking oil drives me insane and I trace down the leak and attack it with vigor. On my T, I just crawl under the car once a week and wipe up as much of it as I can and call it good. The constant leaking and my constant wiping creates sort of a poor man's clean (ish) chassis rust prevention program. At least that's what I like to tell myself.
1924 Touring
- First Name: Thomas
- Last Name: Loftfield
- MTFCA Number: 49876
- MTFCI Number: 24725
Re: Oil Containment
Much depends on the vintage of the car. My two early (1909 and 1910) Buicks seep oil everywhere, they were designed that way. These cars have valve-in-head (overhead) valve trains, all external (makes a great show when running). Oil was intended to ooze up through the tappet holes, otherwise there would be no lubrication, but because it is all open, the oil has nowhere to go but all over the engine. The rocker arms are exposed, need oiling by hand every 40 miles or so, an oil can is supplied on the dash, but there is nowhere for that oil to go but down onto the engine. Ditto the transmission. Back in the day you either had a chauffeur to keep the engine clean, you had a wiping rag at hand, or you lived with oil on the floor of the barn. The early Fords had open valves, obviously leaked. My 1912 Fords have separate valve covers, leak a lot less, but, indeed, if it isn't leaking something it isn't a Model T or the oil is too low. The expectations were just different. As L. P. Hartley wrote: "the past is a foreign country, they do things differently there". If you can't live with oil on the engine (and elsewhere) maybe you should stick with modern automobiles.
- MTFCA Number: 24868
Re: Oil Containment
Are your oil return holes in the tappet area plugged up?
