How to tell if I have a reground cam?
Posted: Mon Feb 01, 2021 8:34 pm
by BillyBobsSpeedShop
I was curious if there was away to see if my cam is a reground cam. Not sure if there are markings or anything.
Re: How to tell if I have a reground cam?
Posted: Mon Feb 01, 2021 8:43 pm
by Les Schubert
Stock T cam is about.250 lift.
Posted: Mon Feb 01, 2021 11:29 pm
Check to see if at the heel is at the same level as bearing area. When cams are ground new, the area on the heel will be a little higher then the bearing surface so it will not slide into the bearing, it would have a shoulder.
Posted: Tue Feb 02, 2021 10:02 am
by Adam
Post a picture
Posted: Wed Feb 03, 2021 10:12 am
The pictures are not the best
Posted: Wed Feb 03, 2021 11:52 am
My gut feeling says, no has not been reground.
Posted: Wed Feb 03, 2021 12:32 pm
by Adam
From looking at your pictures, it is unlikely that it is re-ground.
If it has been re-ground, then odds are very good that it was done to a high quality standard, but you are very unlikely to find one of those in an unknown, used motor.
Most re-ground cams are not done to a very high quality standard. You can generally spot one of those because the heel of the cam is actually ground into the shaft area of the cam.
