Early steering column
Topic author - Posts: 223
- First Name: Michael
- Last Name: Abbott
- * REQUIRED* Type and Year of Model Ts owned: 1912 C-Cab
- MTFCA Number: 49918
Would anyone know if the early 11/12 steering column / mounting flange section at the fire wall be the same between Left Hand Drive and Right Hand Drive vehicles.
Re: Early steering column
I don't think so Michael. One of the lower holes is off-set. That hole will be different from L to RHD. This will also mean that the outer metal shell on the column will also be different on the firewall side of the lower flange. This won't be seem when any column is fitted.
- Last Name: Abbott
Thanks Allan
- First Name: Darel
- Last Name: Leipold
- MTFCA Number: 823
- MTFCI Number: 953
60 year ago I built up a right hand drive `1909 roadster using a cover from England I used the original steering column. I used a new dash and it worked just fine. I altered the parts on the left hand column.
- First Name: Darel
- MTFCA Number: 823
- MTFCI Number: 953
here is a photo from 1957
- Attachments
- clipping_66687543.pdf
- (343.97 KiB) Downloaded 137 times
- Last Name: Abbott
Thanks fellas
I cannot open that last attachment.
Can anyone else?
Might be me
Michael
Can anyone else?
Might be me
Michael
- MTFCA Number: 4838
- MTFCI Number: 115
Here is Darel’s picture
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
It is my understanding the mounting holes on the 1911 steering column are symmetric. The one lower offset hole came along in early calendar 1912. I don't remember why they changed it, or when the changed it back.
- Last Name: Abbott
Thanks Keith
