OT: How to drill a neat hole in an enameled pail?
Posted: Mon Mar 04, 2019 6:43 pm
by Chris Bamford
I need to drill two holes in this pail. One about 1" diameter in the bottom, and a second one about 1/2" diameter near the top.
I expect this coating will want to crack and/or chip — any suggestions for doing a neat job on this?
Re: OT: How to drill a neat hole in an enameled pail?
Posted: Mon Mar 04, 2019 7:02 pm
by Angmar
I have used porcelain bits in the past, starting small and going up. Easy does it kind of thing.
Posted: Mon Mar 04, 2019 7:21 pm
by Henry K. Lee
Using a small grinding stone in the area to be drilled down to bare metal is the key. Take your time and she will come out great.
All the Best,
Hank in Tin-A-See
Posted: Mon Mar 04, 2019 7:47 pm
by Rich Bingham
Just nosey . . . why do you want to drill holes in that pail ? Enamelled steel articles aren't easy to come by. Would something else do ?
Posted: Mon Mar 04, 2019 9:07 pm
by CraneJon
Makin a still?
Posted: Mon Mar 04, 2019 9:17 pm
by ModelT46
I use a diamond coated glass drill bit.You will want to run cooling water when using a glass drill bit.
Posted: Tue Mar 05, 2019 9:58 am
by Chris Bamford
Thanks all for your comments. I'm going to start with Henry's suggestion.
Rich Bingham wrote: ↑Mon Mar 04, 2019 7:47 pm
HI Rich — I need the look of porcelain and an intact inside coating for this project. I'll post some photos when complete (a month or two).
This pail is indeed in nice shape but may not be as old as it appears. The material is fairly light and the label has a newer look to it. A bit of online poking around suggests this piece dates back to the '50s. I combed a couple of antique malls yesterday looking for this sort of thing and was surprised how much enamelware is still around.
Posted: Tue Mar 05, 2019 10:09 am
by HPetrino
I'd use a diamond coated bit as Daryl suggests. I've used them on similar things recently and they work well. Just keep a spray bottle of water handy and cool it regularly.
Posted: Tue Mar 05, 2019 10:13 am
by Scott_Conger
Still a shame to drill a hole into something so nice that a collector would likely display...label and all.
Posted: Tue Mar 05, 2019 10:33 am
by Tmodelt
I am not endorsing any store or product, but Lowe's sells a rattle can of paint that resembles the blue enamel campware. I haven't used it yet but plan on picking up a can to tryout the next time that I pass one of their stores.
