Crank Handle
Posted: Thu Feb 04, 2021 11:48 am
by Original Smith
An original 1912- early 1914 crank handle and rivet sold on ebay this morning for $52. Did any of our members get it? My question is, the rivet. The photos didn't show it clearly. That rivet should have the high head like the hub bolts do. You almost never see anything like this. Great find!
Re: Crank Handle
Posted: Thu Feb 04, 2021 3:31 pm
by Adam
I have several of the handle rivets that are nos.
Re: Crank Handle
Posted: Fri Feb 05, 2021 10:04 am
by Original Smith
Adam. I'm sure you do, but do any of them have the domed head like all the early ones do?
Re: Crank Handle
Posted: Wed Feb 24, 2021 1:45 pm
by Adam
I finally got to my swap meet bins and dug them out. Here they are. I’d take $50 for a NOS pin and sleeve. Let me know. A pin only would be $20.
Re: Crank Handle
Posted: Wed Feb 24, 2021 1:57 pm
by RajoRacer
Here's a copy of an "early" original - slotted dome head & threaded for nut on backside.
Re: Crank Handle
Posted: Wed Feb 24, 2021 2:52 pm
by Adam
I believe that’s a ‘10-‘12 handle & pin in your picture.
The sleeve in my picture is ‘14-‘22. The late ‘12-‘14 sleeves are aluminum. I believe all the late ‘12-‘22 pins should be interchangeable.
Re: Crank Handle
Posted: Thu Feb 25, 2021 11:20 am
by Original Smith
I just checked both of my '13s and my early '14 and they all have the convex domed high head rivet just like the hub bolts. Why doesn't any one make them?
Re: Crank Handle
Posted: Thu Feb 25, 2021 8:22 pm
by Michael A
I always thought the aluminium handle was correct for early 12.
Not sure now which one is actually correct. Seems to overlap in this catalog.
Michael A
Re: Crank Handle
Posted: Fri Feb 26, 2021 7:35 am
by Original Smith
Not a good idea to rely on modern repro parts catalogs!
Re: Crank Handle
Posted: Fri Feb 26, 2021 10:28 am
by TRDxB2
Original Smith wrote: ↑Fri Feb 26, 2021 7:35 am
Absolutely! There "repro" ("will fit") parts all years. Some may match some years or none. The INTERNET & Forum can help resolve. There were repro 19-25 coil box lids that looked good from across the street but were spot welded instead of tabs and had warped sides. Vendors don't sell them anymore. There are many good reproductions and enhanced parts (made for safety or improved maintenance) too but as they say
Caveat emptor
Re: Crank Handle
Posted: Fri Feb 26, 2021 5:20 pm
by Michael A
So which crank handle is correct.
Is 11/12 and 13/14 the same.
Re: Crank Handle
Posted: Fri Feb 26, 2021 5:28 pm
by DanTreace
Just for more interest, factory print on the alum handle with the lathe turning, note the finish comments as 'Black Enamel' Last rev date is Jan 1912
Typical cast aluminum handle:
Re: Crank Handle
Posted: Sat Feb 27, 2021 6:49 pm
by Michael A
Thank you Dan
