Stamping a new serial on a blank engine block.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Sat Feb 06, 2021 2:16 am
I see where there is currently a thread by Mark Gregush regarding a rare 1926/27 engine block without a serial and I was curious as to how would one go about evenly stamping the numbers into the block without getting them all crooked. However it is done would need to be a foolproof method for one could not afford to make a mistake. You would first need to find a set of antique number stamps of the correct font and size that Ford used. I was thinking that, one could make a guide by making a tracing of an 8 number factory stamped serial number and, using this tracing, make a straight template of the numbers by taking a piece of hardwood and drawing a straight line across the bottom and top of the 8 numbers then a horizontal line exactly through the center then a vertical line through the center of each number and using a center punch, indent a pilot hole in the exact center of each number and drill 8 holes just big enough for the number stamp to fit. Once done you would secure the template over the area above the water inlet so that it can’t move then slide each number into its’ specified hole and strike it hard making sure the stamp was right side up and straight. Considering the rarity of a block without a serial number, I would encourage Mark to rebuild this engine, as I am sure there are a lot of ‘26/‘27 T owners in search of just such a block to install in their T’s to make it a matching number car. Jim Patrick
Kerry
Last Name: van Ekeren
Re: Stamping a new serial on a blank engine block.
Post by Kerry » Sat Feb 06, 2021 2:58 am
It seems you are over thinking it, Ford never did, just smack those numbers in. :D
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat Feb 06, 2021 4:20 am
There is a Service Bulletin that covers how to do this. If you can think of a question of how to do something, there is most likely a Service Bulletin that covers it. Dan
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Feb 06, 2021 7:15 am
I have never seen the numbers straight on a block.
On my frame the numbers are in a semicircle.
Seeing that thread, I fought myself three times from commenting about putting a matching number on the block because that is the practice but it was not clear in the thread that the engine actually came from a car, rather, a loose engine.
Vern (Vieux Carre)
Jeff Hood
First Name: Jeff
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
MTFCA Number: 25636
Post by Jeff Hood » Sat Feb 06, 2021 8:49 am
They weren't straight.
Crooked Serial Number
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Feb 06, 2021 9:37 am
Nothing looks less authentic than perfectly stamped engine numbers. They were always stamped with some variation, some look pretty straight, others look like a 2 year old did it. Do it as Henry did it, one individual stamp at a time.
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Sat Feb 06, 2021 9:45 am
I don’t think Ford used a holder of some sort to keep the numbers straight other than a guy stamping individual numbers by hand.
The stamp employee would line the numbers one at a time and smack the die and that was it.
I’ve had several blocks over the years and none of numbers were perfectly straight.
Some were straighter than others but not perfectly uniform.
I can imagine a guy with a clip board going down the list to keep the block numbers in order and another guy stamping the numbers. But maybe it was done another way.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Feb 06, 2021 9:58 am
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sat Feb 06, 2021 10:26 am
Factory stamps varied, but some are fairly nice, on this photo the skilled stamper is using a metal guide, for a very important engine, all other stamping was free hand, typically with a skilled worker on that task.
Here is the dedicated stamping worker in 1915, one view shows his box containing metal numeral stamps, and the other shows the same worker stamping the numbers on the block. Likely chosen for ability to hit the hammer blow correctly for a deep stamp that is placed best he can.
Ford Service, showing wood box of stamps. Have done blocks with Harbor Freight 1/4" high numeral stamp set, works fine. You have to have a good hard swing, but the iron block takes the imprint OK. Just don't use numerals with serifs on the ends, as those are old time looking, but Ford didn't use that font style on T serial stamps.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Feb 06, 2021 10:55 am
not straight and a double strike
Vern (Vieux Carre)
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Sat Feb 06, 2021 11:01 am
straight, not quite perfect
Vern (Vieux Carre)
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Sat Feb 06, 2021 11:10 am
After stamping hundreds of numbers the guy would get pretty good at doing it. Practice makes perfect or almost!
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Feb 06, 2021 11:48 am
I agree, levels of skill varied. Some numbers are straight and even, others not so much.
This guy got a couple of digits upside down.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Feb 06, 2021 12:05 pm
Stamped blocks being uniform would be a dead giveaway that they’ve been altered. There were devices back then that could have done that automatically. I would guess they debated whether cost effective compared to an individual man doing it all day long. That would be another brutal job there! Another factor was probably the pressure of a strike of that many numbers was perhaps too much risk of cracking a block.
When you look at a lot of blocks, you can certainly tell if a rookie did it, possibly just an uncaring or lazy person, or a person that really had some skill and dedication. A skilled person could use a couple stamps at a strike , and those blocks stick out too, with numbers grouped together. This hand stamping carried into Model A production, but they seem to be a bit more uniform.
Thanks for the posting of those great pics.
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Sat Feb 06, 2021 12:57 pm
Reproduction Ford stamps are available.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sat Feb 06, 2021 12:58 pm
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Sat Feb 06, 2021 1:19 pm
That is an UNUSUAL number stamping set in that Ford Service bulletin...
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sat Feb 06, 2021 1:44 pm
Adam
To me it’s helpful to have the numeral very visible by tapering away the punch sides at those steep angles. That shape helps to see where to stamp the next number beside the last one. Like the belt holder used by this guy!
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sat Feb 06, 2021 2:00 pm
I used to have an engine wth an upside down 4.
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Sat Feb 06, 2021 2:17 pm
"Considering the rarity of a block without a serial number,"
I have seen several engine blocks without serial numbers, but then again I have a milling machine.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Sat Feb 06, 2021 2:31 pm
It's too bad someone altered the casting date on the '16 block Steve posted... you can see the weird shape of the "6" turned into a "5"... At least they didn't mess with the serial number, but I'm not sure how one could change it back to a "6" easily... It also shows the unusual "serifs" on Fords 1 and 2 from that era... finding those stamps might be a challenge!
Kerry
Post by Kerry » Sat Feb 06, 2021 3:59 pm
Susanne, I reckon it was an 8, the engine number pad is a give away too being the longer one.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Feb 06, 2021 5:08 pm
My educated guess would be that isn’t a FORD stamped serial number
Ed Fuller
First Name: Ed
Last Name: Fuller
MTFCA Number: 29582
MTFCI Number: 22818
Board Member Since: 2012
Post by Ed Fuller » Sat Feb 06, 2021 5:42 pm
I agree. The 1 & 2 digits are different than on the other blocks.
kmatt2
First Name: Kevin
Last Name: Matthiesen
* REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
MTFCA Number: 11598
Post by kmatt2 » Sat Feb 06, 2021 7:07 pm
Unlike the Model A era stamps, both early and late styles of A stamps, that were special, the Model T stamps were era standard stamps available at hardware stores. Back in 1972 I was able to by a set complete with wood box. I found the stamps at a old hardware store in Armona Ca. near Fresno. I doubt that they are from the 1920's, most likely they are from the late 1940's to early 1950's but they are the same as used on original Ford stamped blocks. They must have been quite common and there must be some still out there at estate sales and such.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Sat Feb 06, 2021 9:48 pm
I realized as well there were 3 separate sets of stamps used on that block... different sizes, different numbers, etc... 2 different sizes of "1"' (one matches the "3", the other doesn't), and the 2 and 8 are smaller...
I doubt those were done at Highland, and I wonder now if they were even done by Ford, or at a garage stamping a blank block with whatever punches they had...
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Sun Feb 07, 2021 12:13 am
I agree Susanne. With all the supervisors and foremen Ford had on the line, I don’t think they would have put up with such sloppy work from the serial number stampers as is apparent on several of the pictures above. So crooked are the stamped numbers that I doubt that those stamping were done at the factory, but instead were done in a garage on a replacement engine by someone who didn’t give a s—t. The reason I embarked on this discussion is because the numbers on my original ‘26 block are so straight and level that I was trying to figure a way to reproduce that result. I had no idea that the numbers on some blocks were not very well done and that the consensus is, if the numbers are straight, they were not correctly stamped as they were originally done in the factory. Whaaaaat?. It seems that too many T owners have formed the opinion that the Model T is a substandard car not worth the extra effort and that any extra effort is a waste of money and time and not original to the concept that Henry Ford had of his car. There is nothing further from the truth. Henry Ford loved the Model T. It was his baby and his obsession and he was constantly striving to make it better and woe to anyone who got in the way of that or did not share his vision. A lot of our members seem to be of the opinion that Ford workers did substandard work and that any restoration that does not incorporate and perpetuate these substandard practices is “over-restoration”. I’d like to think that Ford had more pride than to propagate the notion that the Ford Motor Company tolerated substandard work. While they probably did not foresee the Model T lasting for 100 years and attaining the status and popularity that it has, they would be shocked and sad to think that the poor work of a careless shade tree mechanic that most likely did not have the money, the skill, or the care to do it right, was being attributed to Ford workers and being perpetuated as original. The Model T may have been an inexpensive car, but it was not a cheap car and I hope that some of the substandard work done by past owners, that has been interpreted as original, will be corrected by doing superior work to bring your T more in line with the well made Ford product that the T was with great workmanship originally done on the assembly line by well trained Ford workers. Jim Patrick
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Feb 07, 2021 10:14 am
The majority of original stamped numbers are crooked, and at best, obviously stamped separately. This is true, especially through the early years. They seem to be getting better by the end of 1927, but they are not perfectly in line like a machine stamping.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun Feb 07, 2021 10:29 am
If you want to have perfectly aligned numbers, there are stamp holders similar to this one that would hold all the numbers perfectly in line.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Mon Feb 08, 2021 11:43 pm
Dan, what Service Bulletin issue has the article on block stamping? I have a complete set, and all I can find is an issue that lists the motor numbers used for given years.
Erik Johnson
First Name: Erik
Last Name: Johnson
Post by Erik Johnson » Tue Feb 09, 2021 12:16 am
Slight drift:
I have a spare block in my garage and the serial number is only nine off from the block in my unrestored '17 roadster, both corresponding to May 26, 1917.
Only the last digit of the serial number differs - 0 vs 9.
However, the block in my car has a May 25, 1917 casting date while the spare block has a May 24, 1917 casting date.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Feb 09, 2021 9:37 am
The picture and instructions are from April 1, 1919 Service Bulletin. Another ref. about not grinding off old numbers in re-stamping is in July 1925 Service Bulletin.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Thu Feb 18, 2021 8:13 am
There was a device that held all those numbers in an even row and had a turn screw on the end to tighten them in place.
The handle was a coiled section of about 3/16th inch wire that looked like the tool used to lift the lids off old wood cook stoves to add more wood.
I saw a photo of it years ago, but I do not remember where.
Stampings made at the factory with that tool were always very even.
Stampings made on replacement engines were never even in position or depth.
An armature can easily break or crack a block if a single stamp is hit too hard.
There was an art to those replacement stampings.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Thu Feb 18, 2021 11:51 am
Had to have been loud in there....none of them are wearing hearing protection.
1924 Touring
Joss
First Name: Joss
Last Name: Sanderson
Post by Joss » Thu Feb 18, 2021 7:53 pm
Just get a set of stamps. They do not need to be exact Ford repro stamps. If building up a car be sure to check to make sure number is good.
The reason to check the number is my 26 is registered with #14625. Obviously three digits missing. Took 3 tries to pick a good number. And FWIW, neither Washington, Oregon or Arizona cared that the number made no sense.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Feb 19, 2021 11:41 am
The numeral 1 has both serifs on many engines, but in the service bulletin photo of the stamp set it has only the top one.
https://www.harborfreight.com/14-in-ste ... mber+stamp
Chris Haynes
First Name: Chris
Last Name: Haynes
Post by Chris Haynes » Fri Feb 19, 2021 1:21 pm
`You have to remember that blocks have a date code cast into them.
Don D
First Name: Don
Last Name: Demio
* REQUIRED* Type and Year of Model Ts owned: 1919 T
MTFCA Number: 27167
MTFCI Number: 20405
Post by Don D » Fri Feb 19, 2021 1:41 pm
FYI, here are several photos of an unstamped Model T block with a mold mark of 25 S and the Ford script and USA in the area partially covered by the lower water inlet. If you can look closely you may be able to see the boss machining marks that come down and arc to the left.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Feb 19, 2021 3:26 pm
Dom
That script just confirmed to the buyer, it was a genuine Ford block, ready to be assembled by the dealer shop or another repair shop back then.
Ford must have figured that was needed to guarantee the buyer.
There were ''spurious" parts out there by golly. :o
Image 1-21-21 at 9.28 PM.jpeg (61.45 KiB) Viewed 4255 times
Or perhaps these blocks were the ones sold to dealers, that came complete with most of the internals to assemble into a completer motor. At this time seems the factory could not ship out complete finished and serialized motors to dealers. So bare blocks with parts were sold.
Image 5-3-20 at 12.26 PM.jpeg (96.75 KiB) Viewed 4255 times
Here is another with that Ford and USA, but with a serial number stamp. Since its an Improved Block, was stamped with Ford, as even the later cylinder heads didn't have Ford script on top!
OilyBill
First Name: William
Last Name: May
Post by OilyBill » Fri Feb 19, 2021 5:32 pm
I agree with Jim Patrick.
The engine numbers on my 1914 are near perfectly aligned.
If you read the book "Ford Methods and the Ford Shops", you will get a really good idea of how good Ford production methods were. There was NOTHING left to chance in the manufacture of a Model T Ford, at least after the moving assembly line was instituted. There may have been some sloppiness prior to that, but I don't think there was much, and after that point, I guarantee you there was no sloppiness whatsoever!
Every single step and operation in the production of a Model T was time-studied, analyzed, costed out, and checked and double-checked.
As they make clear in the book I mentioned, EVERY DAY, THE FORD COMPANY MOVED EVERY PART IN PERFECT SYNCHRONISATION TO INSURE THERE WAS NO SHORTAGE OR EXCESS OF ANY PART at every point of the assembly line.
I can't believe they ever left anything to chance. That would not be like the Ford engineers to have skipped that.
Every day, they moved the exact amount of material to build a certain number of cars, and every day, ALL those cars were shipped. There never was any storage of Ford cars at the factory.
It is true there were reserves of parts. I was amazed to discover that they kept as many as 40,000 pieces of a particular part in reserve. (This was part of how Henry paid off all the stockholders when he turned every single part he had in stock, into cars, and then shipped them all to raise the funds to beat the Wall-Streeters who were hoping to take over Ford when they thought he would run out of money.) Clever Henry knew what he was doing.
david_dewey
First Name: David
Last Name: Dewey
MTFCI Number: 19936
Post by david_dewey » Wed Feb 24, 2021 2:51 am
My recently acquired '26 frame is stamped, and I thought it interesting that both 8s are upside down. Apparently this happened frequently???
Frame number email.JPG (36.15 KiB) Viewed 4109 times
T'ake care,
David Dewey
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Feb 24, 2021 5:24 am
Some original numbers were stamped fairly straight, most are crooked or at best, not aligned. The assembly line was not a perfect beast, and there are plenty of examples of shoddy work or mistakes on original cars.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Wed Feb 24, 2021 9:06 am
So far, nobody has figured it out...
Poppie
First Name: Neil
Last Name: Martin
* REQUIRED* Type and Year of Model Ts owned: 11 tourer 18 tourer 18 TT
Post by Poppie » Wed Feb 24, 2021 5:45 pm
OK, What is the last stamp (letter/figure) in the red box? Is it the number 6 or 9 or is it a . (dot)....N..... :roll:
Don D
First Name: Don
Last Name: Demio
MTFCA Number: 27167
MTFCI Number: 20405
Post by Don D » Wed Feb 24, 2021 7:35 pm
The far left stamp in the red box is an &. The ampersand is also known as the and sign.
Post by Allan » Wed Feb 24, 2021 9:38 pm
The red box has 9 rows of 4 stamps = 36, 26 letters, 9 numbers and the ampersand = 36. I wonder if they are the same height as the original T numbers. My set are old style numbers, but there is no C stamp for the Canadian numbers. I found a Q stamp in a junk store and ground the pigtail off with my Dremel tool.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Feb 25, 2021 1:13 am
Quite true. It can be anything from paint drips to coil box terminal nuts with the holes off center. :D
