lubrication on the crankshaft bearings
Posted: Sun Feb 07, 2021 1:46 pm
Hello Everyone
I would like to ask for some advice regarding what is current for the crankshaft and rod bearings as far as cutting grooves in the babbit bearings for lubrication. I have recently dismantled what appears to be a recently reconditioned engine and had become "stuck". On all of the rod bearings and main bearings there are no grooves cut in them. Therefore would this prevent or restrict crankshaft lubrication? Your comments would be appreciated. Thank you John
