Screw size for dash shield
Topic author - Posts: 1098
- First Name: Mike
- Last Name: Bird
I just got a dash shield and guide for a two piece dash 11-12. Unfortunately the dash shield did not come with the mounting hardware (screws).
I do know that the screws are to be #6 Slotted Round head but what is the length? Thanks
Mike
Mike
Re: Screw size for dash shield
Not so long that they go right through the firewall. No-one will know if you use some thatare a bit shorter than Henry used.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Mike-
I'm sure someone who has those specifications will post it. Regardless of the length, I would suggest you drill the holes and "thread" the wood using a matching thread steel Phillips head screw before you put in the slotted French head brass screw.
Those fancy brass screws have a tendency to twist in two. Don't ask me how I know.
Keith
Keith
- MTFCA Number: 121
- MTFCI Number: 16310
Keith, I hear you on that one. I had it happen to a #8 oval hood former screw. It was a chore to remove it.
- First Name: Paul
- Last Name: O'Neil
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1923 Runabout
- MTFCI Number: 18018
Years ago an old timer told me to soap wood screws to ease their passage into the wood. Is anyone doing this now? Do they come loose more easily?
- First Name: Mike
- Last Name: Bird
Great ideas guys!
Mike
Mike
- First Name: Bill
- Last Name: Hoffer
- MTFCA Number: 32571
- MTFCI Number: 24364
Soap definitely works! Dad's favorite trick. Great idea on prethreading the hole! Cheers, Bill.
- First Name: Michael
- Last Name: Krom
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touring, 1923
- MTFCA Number: 50947
Dad's trick was to scrape the woodscrew threads across a piece of Bee's Wax!
Something I still do!
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout
- MTFCA Number: 50076
I have used the soap and bee's wax trick for years! My grandfather always had a small bar of soap in his toolbox and he would drill a hole in the wooden handle of his hammer and put bee's wax in it so as to always have it on hand!
David - Yukon, OK
- First Name: Paul
- Last Name: O'Neil
I just ran the No. 9 brass wood screws into the dash to hold the horn. It was hard going in dry, I had forgotten the old wisdom. Oh well, next time!
