Cowl lacing 26/27
Posted: Mon Feb 08, 2021 4:32 pm
by dmdeaton
Radiator shell turned out pretty nice. Cowl lacing looks self explanatory except for the 2 at the bottom. Bottom looks easy as the back is easy to get to so the rivet can be split. The next one up seems like a rigid nail. What is the fix for that one?
Re: Cowl lacing
Posted: Mon Feb 08, 2021 4:35 pm
by dmdeaton
Is there a hook like the model A has that clips over this?
Re: Cowl lacing 26/27
Posted: Mon Feb 08, 2021 9:01 pm
by DanTreace
No hook like an A. Been a while, but recall slipping in a piece of busted hack saw blade or something as the backing bar to force the split tangs of the rivet to seat on the backside. Those lower holes are a bear, the others are OK, if you have the gas tank out!
Think I used an ice pick to make the hole a bit bigger and spread the tangs just so, before insertion, that helped them spread open. Have Fun!
Posted: Mon Feb 08, 2021 9:29 pm
by dmdeaton
I found some earlier posts on this. You replied then. My fuel tank is out. A couple fellows said they used pop rivets
Posted: Mon Feb 08, 2021 10:00 pm
by John kuehn
That probably was a job that the Ford line guys did before the body parts all came together so you could have nothing in the way to put the rivets through the lacing.
Posted: Tue Feb 09, 2021 9:27 am
by dmdeaton
John
I agree
Even with the dashboard and fuel tank out itβs a bear. I am glad I started to tackle this before I mounted the fuel tank and dash. I never gave it a thought, usually Iβm the one doing things 3 or 4 times to get it done.
Posted: Tue Feb 09, 2021 5:49 pm
by dmdeaton
Posted: Tue Feb 09, 2021 5:51 pm
by dmdeaton
Right or wrong I got it done
1/8 inch pop rivets with washers on the backside
