Help ID Aux Drive
Posted: Mon Mar 01, 2021 6:03 pm
by A Whiteman
I have been contacted for information on the auxiliary drive pictured below. I have no further information than that it was used on a Model T. I believe it was fitted to the front ratchet (as many accessories were).
From the pictures provided by the owner I cannot see how this was fitted or how it would have worked. There is an output shaft that had a pully attached which had been cut off. The owner is having a new shaft built and fitted.
The arm 'bent to 90dgrees' seems to have been the crank handle with the other side fitted to the engine crank socket - but I am not sure...
Can you help please with an ID of the unit and how it may have been operated?
Many thanks
Adrian
Re: Help ID Aux Drive
Posted: Mon Mar 01, 2021 8:00 pm
by Michael Peternell
I'm guessing it's a governor for a stationary unit.??? Title of post made me think of other things.
Posted: Mon Mar 01, 2021 8:35 pm
by Bill Coyle
The universal on the input shaft looks like the same one on my Willys Overland Whippet. It has the flange that bolts to the transmission output shaft. With the pulley at 90 deg I'm guessing it's a pto accessory. Many Whippet engines were turned into power units.
Bill
Posted: Tue Mar 02, 2021 10:18 am
by DanTreace
Adrian
From the oval like plate on that PTO, my guess it is an " E-Z Power" brand power take off.
Here are some photos:
E Z PTO.jpg (41.08 KiB) Viewed 2042 times
There were a few different mfg. of these front crank mount drives, here are two:
Posted: Tue Mar 02, 2021 10:44 am
by DanTreace
And...
Here is link to earlier post on these, this link has others for discussions too. A nice print on the factory drive collar for making a new one.
http://www.mtfca.com/discus/messages/41 ... 1408370269
Other pics, took these at museum in Montana, was on front of a TT.
Posted: Tue Mar 02, 2021 5:40 pm
by A Whiteman
Thanks Dan, that does in deed look like an EZPower,
Cheers
Adrian
