Five bearing crank?
Topic author - Posts: 40
- First Name: Kyle
- Last Name: Hill
- * REQUIRED* Type and Year of Model Ts owned: 1925 depot hack. 1924 4door 1920s racer 1923 TT
Five bearing crank?
Any one have any pictures of some of the original five bearing cranks installed or how they were installed?
- First Name: Michael
- Last Name: Peternell
- * REQUIRED* Type and Year of Model Ts owned: TT gas truck, T tractor conversions, '15 touring, '17 speedster, '26 16 valve speedster
Re: Five bearing crank?
Can you post a picture of the book you have? I would like to be able to read the whole page. No offense, but I can't now.
- First Name: Ed
- Last Name: Martin
- First Name: Les
- Last Name: Schubert
If you want to go the “5 main conversion” route I have available exactly ONE conversion “girdle”. The concept is that ALL 5 main caps are in one casting. I’ll try to post a picture tomorrow.
If someone wants to buy the 5 main block patterns please contact me. They are available. With some modifications they could be used to make open valve blocks or straight 8 blocks
- First Name: Kevin
- Last Name: Pharis
Les!!! You tease...!
- First Name: Kyle
- Last Name: Hill
The book is model t speed and sport.Michael Peternell wrote: ↑Mon Mar 01, 2021 7:20 pmCan you post a picture of the book you have? I would like to be able to read the whole page. No offense, but I can't now.
- First Name: Kyle
- Last Name: Hill
Sounds interesting. I’ve read about your block. It’s pretty impressive. I’m mainly looking for info on the original bolt in conversion.Les Schubert wrote: ↑Mon Mar 01, 2021 8:22 pmIf you want to go the “5 main conversion” route I have available exactly ONE conversion “girdle”. The concept is that ALL 5 main caps are in one casting. I’ll try to post a picture tomorrow.
- First Name: Les
Crank side of girdle
Girdle as it would be installed
A suitable crank
- First Name: Kyle
- Last Name: Hill
That’s really cool Les definitely interested. I think I understand where you’re going with that. Does it take a special pan?Les Schubert wrote: ↑Wed Mar 03, 2021 3:49 pm18C60F77-BFC5-4A3E-A56B-4B2743D75883.jpeg
A suitable crank
- First Name: Kyle
- Last Name: Hill
Les could you please send more information and cost?
- First Name: Les
It will fit into a ordinary pan. Pressure oiled
- First Name: Les
The crank you see was custom made by Crower. I’m sure they still have the drawings!! Definitely more than a Scat crank!
- First Name: Kyle
- Last Name: Hill
Gotcha LesLes Schubert wrote: ↑Wed Mar 03, 2021 4:35 pmThe crank you see was custom made by Crower. I’m sure they still have the drawings!! Definitely more than a Scat crank!
- First Name: Stan
- Last Name: Howe
- MTFCA Number: 19133
I saw these blocks and 5 main cranks by Crower when Les stopped by with them a few years ago. They are incredible. I think the first one went in Karin's speedster. I dunno about the rest. I'd like one but the piggy bank is pretty thin this year.
Send Les money. US Funds.
- First Name: Les
Stan
Thank you for the kind words. UNFORTUNATELY DONT send me money for a crank as I have none left. I will provide permission to Crower to use the drawings. I have exactly one of the girdle castings available but I still have the pattern, so more can be made. My preference would be to sell the pattern (just like the block patterns as well). Getting older and LOTS of projects in the que!!
- First Name: Kyle
- Last Name: Hill
Les how much for the girdle and the crank? I contacted crower but no luck on getting info for a crank.Les Schubert wrote: ↑Wed Mar 03, 2021 8:05 pmStan
- First Name: Les
Talk to Peter Harris at crower
- First Name: Stan
- Last Name: Howe
Don't worry Les, I don't have any money and like you, have projects to last until I'm at least 90!!!.
- First Name: Layden
- Last Name: Butler
Kyle,
To answer your original question......Here is how it was done back then. Since they interfere with a camshaft in the cylinder block these were intended to only be used under a overhead cam setup.
- First Name: Kevin
- Last Name: Pharis
Waaaaay to cool Layden!!
- First Name: Les
I love it!!
- Last Name: Butler
So who has a good crankshaft available to match these??
- First Name: Les
If one like the picture I posted would be suitable, then Crower can help you. 4 months ago I possibly could have, but I have put it to use!
- First Name: Kyle
- Last Name: Hill
Thanks Layden exactly what I was looking for.Layden Butler wrote: ↑Thu Mar 04, 2021 9:06 pmKyle,
