Found a few more pieces can anyone identify?
Posted: Wed Mar 10, 2021 2:05 pm
by FATMAN
Going through the shop and found some more oddball things, I know a lot of you guys have other cars plus the T's
see if you can figure out what they fit, thank you, Bob
Re: Found a few more pieces can anyone identify?
Posted: Wed Mar 10, 2021 2:06 pm
by FATMAN
another part
by FATMAN
another part
Posted: Wed Mar 10, 2021 2:07 pm
by FATMAN
short bracket
Posted: Wed Mar 10, 2021 2:09 pm
by FATMAN
top bow saddle with unusual bracket
Posted: Wed Mar 10, 2021 5:56 pm
by Wayne Sheldon
Pretty sure the first four are mounting brackets for after-market headlamps. Probably for drum style lamps as that was what I saw on some very similar brackets. A truss rod crosses in front of the radiator to reduce vibration and maybe mount the license plate. Brackets and headlamps had a dished mating area with some slop in the bolt hole to loosen the bolt and swivel the lamp for proper aim adjustment, then tighten the bolt. Nice items. Hard to find the brackets, and a lot of lamps from other cars used similar dished adjustments and could be used on a model T.
Third post photos are of tail lamp bracket. A lot of tail lamps, both factory and after-market, had the socket going straight out the back, with two mounting bolts, one on each side of the socket.
Second post? Got me.
Posted: Wed Mar 10, 2021 6:02 pm
by FundyTides
The bracket marked 81Y 13471 is a Ford part and according to the number is a left rear lamp bracket for a 1938 Models 81C, 81Y and 83 L.H.D. 81C is Commercial Chassis, 81Y is 122"WB Truck. Can't find any reference to what the 83 is. Info is from my 1928-38 Ford Parts book. Do any of the other parts have obvious Ford part numbers?
Posted: Wed Mar 10, 2021 6:15 pm
by Mark Gregush
The top bracket should have a number on it. While that will not help find what the iron came off, it would help someone that needed a saddle. Some came in left/rights others could be used on ether side.
Posted: Wed Mar 10, 2021 9:09 pm
by Wayne Sheldon
I would imagine that you only have the one of those top saddles? Pairs are better to sell, as they made so many (hundreds!) of variations and finding two separate ones that match can be very difficult. I think this one is for a roadster. Most touring car saddles were longer/larger/taller (however you want to look at it?). To add to what Mark G said, It looks to me like this one doesn't have specific 'rights' and 'lefts'. Usually those had a forward or backward offset, and I don't see that in this one.
Posted: Thu Mar 11, 2021 10:53 am
by FATMAN
The top saddle does have a number, hard to read
it is either A17 or 417, Bob
