Bad carb float again?
Topic author - Posts: 913
- First Name: Ignacio
- Last Name: Valdes
- MTFCA Number: 50406
Hi all, Back again after the Texas armageddon freeze. I've spent the last few weeks recovering and finally getting down to rewiring the house for solar critical load panel and a generator for hurricane season.
A few years ago I had a bad carburetor float. Gas pouring out of the Holley NH. I bought a new float and it fixed the problem. The car had been running fine for months, until this past week. Nothing done to the carburetor. It is baaack! Gas pouring out of the carb throat and it will not start until I turn off the sediment bulb gas. I checked and reset the float angle to 1/4 inch gap but it still is pouring gas out. Do carb floats go bad that fast? I didn't do the boiling water float test yet. Could it be anything else?
-- IV
-- IV
- MTFCA Number: 16175
- MTFCI Number: 14758
Re: Bad carb float again?
Yes, it could be a bad float valve. What do you have?
- First Name: Bob
- Last Name: Shirley
- MTFCA Number: 29135
Shake the float and generally if it has gas in it you will feel the gas and see a wet spot. You can also drop the float in very hot - but not boiling water, hold it submerged with a stick or something and check for air bubbles. If you see bubbles you got a problem.
- Last Name: Valdes
Holley NH. They can go bad after only a few years?
- Last Name: Patrick
- MTFCA Number: 50126
Hollow brass or shellacked cork? When selling the float, be sure to measure from the flange to the top of the float. Jim Patrick
- Last Name: Valdes
Hollow brass purchased from a reputable vendor. I think I measured and re-set the float correctly per the diagram. It has been working fine for the last few years so I am at a loss as to why it suddenly has developed a problem.
jiminbartow wrote: ↑Sun Mar 14, 2021 1:29 amHollow brass or shellacked cork? When selling the float, be sure to measure from the flange to the top of the float. Jim Patrick
- First Name: Robert
- Last Name: Thompson
What kind of float VALVE (NEEDLE AND SEAT) DO YOU HAVE?
- Last Name: Hatch
- MTFCA Number: 49974
What gas mixture are you using in it. Pure gas or?
- MTFCA Number: 51486
Dirt.... dirt in the fuel line... just blow it away....
No, I meant to ask Bob's question. What kind of valve? Some of them are prone to sticking and leaking. Some of them also come with a gasket that's too hard to seal, so gas leaks around the seat. Your flooding could be due to a sinking float, or a leaking valve, or both.
- Last Name: Valdes
The float is tested in hot water there are no bubbles and I see no obvious holes or damage. Shaking it I hear no liquid inside. The needle is the Viton tip kind. This is a Russ Potter rebuild from 4 ish years ago.
- MTFCA Number: 14972
- MTFCI Number: 15411
Ignacio - is the gas tank an original ? If so, perhaps there is residual crud getting to the float needle & seat.
- Last Name: House
- MTFCA Number: 115
Our dearly departed friend Jack Daron told me how to test the functionality of an NH float :
Lay it down on a concrete floor and stomp on it. If liquid splattered out onto the floor, it wasn’t any good.
I don’t know why I turned out this way. My parents were decent people
- Last Name: Valdes
Seat looks clean, see picture. In thinking about this I did recently grease the sediment bulb petcock valve and the carburetor fuel line nut and elbow with fuel-proof grease to stop fuel from seeping. That coincided with this problem. However, I am failing to see how that would be a problem but I have no explanation for the current situation either. Could the grease have traveled and make the fuel valve stick open somehow? I could try a Q-tip on the valve bore.
- MTFCA Number: 4838
- MTFCI Number: 115
Use some carb cleaner or lacquer thinner, avoid cotton swab due to cotton particles. As posted, a speck of trash, including a dab of gas resistance grease, can stick the needle.
If a Vitron tipped needle, look for white residue around the cone that sets in the seat. That is residue from gas sitting ther, can stick a needle shut, esp. with ethanol in the gas.
Sometimes the brass hinge pin can hang up, after adj. the float to 15/64" so be sure the float can move freely. But not too freely , side to side, as the float can hit the side of the bowl.
Check the float isn't compromised with a leak.
Using the Service Manual method of inverting the carb, allows float to hit the needle, and test with suction from the mouth. Light suction and a well seated needle will stick your tongue to the elbow. When you turn the carb over, the float falls free, and suction won't stick your tongue to the elbow. Of course, carb should be dry for this final test of float adjustment
- Last Name: Hatch
I try to used gas without ethanol when I can.
Also, do yourself a favor and get one of Scott’s bigger size float valves and one of his installation tools. Dan
I've had Viton tips stick, but the trouble from that was fuel starvation, not flooding. I was lucky enough to get a few original needles in some auction plunder.
You can resurface a needle by putting it in a drill chuck and turning it against a fine sharpening stone. If I needed a new needle I would get one from Scott Conger.
- Last Name: Valdes
I cleaned the valve with carb cleaner and wiped the needle thoroughly and that seemed to have fixed the problem. Remarkable that the fuel resistant grease must have traveled to the needle and stuck it open. Thank you for the help.
Dan, it looks like your gauge is upside down. Square side should seat against the flange and round side should face the float. The way you have it, there appears to be a gap under the gage on the flange side, which will make the gap wider than 15/64. Jim Patrick
- Last Name: Valdes
I spoke too soon. We drove Shirley the 1922ish Model T touring to church. I turned it off waited about a minute and things looked good no leaking. I came out an hour later and it was leaking again out the throat of the carburetor but not as badly as before. There was a puddle of gasoline under her. Sigh, not out of the woods yet.
How to about a new set of gaskets. If the carb is air tight, the fuel should not leak out and the gas should only flow when the engine is running and pulling in fuel. If air gets in anywhere, it allows the gas to flow. Sort of like when you stick a straw in a drink and put your thumb over the end and pull the straw out, the liquid will stay in the straw, but release your thumb and it all pours out. Jim Patrick
- MTFCA Number: 14383
it dont work that way jimmy. under the nh tag is the air inlet for fuel mixture. it will pour out there or back thru the choke side of the carb.
Actually John, that is how it works. When the float is adjusted right and the gas rises to the point of causing the needle valve to seal the inlet, preventing anymore gas from entering, the needle valve acts as the the thumb on the straw and keeps the gas from gushing out. If the float is adjusted wrong or the needle valve is not sealing properly, the seal that creates the vacuum that keeps the gas from flowing is broken and the gas gushes out. Good gaskets also create the necessary seals to prevent leakage. One of the tests that is done to determine if the needle valve is sealing properly is to suck on the fuel inlet angle fitting (#6203 in the drawing). If no air comes through, you have a good seal. If air comes through, you don’t. Without a good seal, gas continues to flow in causing the cup to overflow. Jim Patrick
- Last Name: Valdes
So I need to do the vape thing with my carburetor? Seems a little embarrassing but I will try it.
"How to about a new set of gaskets. If the carb is air tight, the fuel should not leak out and the gas should only flow when the engine is running and pulling in fuel. If air gets in anywhere, it allows the gas to flow. Sort of like when you stick a straw in a drink and put your thumb over the end and pull the straw out, the liquid will stay in the straw, but release your thumb and it all pours out. Jim Patrick"
your answer here claims gaskets will solve the problem.
clearly, the problem is in the needle & seat.
If i am confused by your post, a hundred other guys that dont know any better may also be.
If the carb was air tight the bowl wont even fill. Submerse a drinking glass upside down in a bucket of water. Notice it wont fill. hense the breather hole to the bowl & the air inlet under the .id. tag on the other side of your diagram that is not shown or referred to. remove the needle & fuel will run out under the tag & out the choke side of the carb. like the problem described.
Ignacio. See Dan Treace’s March 14, 4:18 pm post, figure 440. It was a common method found in the Model T Ford Service Manual that Ford recommended mechanics use to test the integrity of the needle valve. The suction should be so good that it will hold your tongue to the fitting. I agree John. The problem is most likely in the needle and/or the seat. Jim Patrick
- First Name: Corey
- Last Name: Walker
- MTFCA Number: 51502
You can turn the carb upside down, put the needle into the seat and spray soapy water all around it, then hold a little pressure on the needle with your finger and put a little air pressure to the fuel inlet and the bubbles will show if the needle is leaking or the gasket is leaking if bubbles come up between the seat and carb body.
1.With the carb installed, drain a bowl full into a clean glass jar. (looking for dirt bits. can cause intermittent & temporary seating failure)
2. look at viaton needle for damage, nicks, off center tip & marks.
3. Do the suck test. (preferably with out the elbow to eliminate possibility of a slight leak there that will mess with suck test results.)
4. your tong should hole for a good minute.
I ran into a situation with some new metal needles. Restored a carb. passed the suck test. After a while it leaked. Reseated the needle (light tap to needle). Did another suck test. passed. turned needle 180 degrees. failed suck test.
Turned out that needle point was not machined centered. It was off more than the needle body & needle clearence.
So if carb passes the suck test, rotate needle to different positions & repeat.
- First Name: Don
- Last Name: Kirtley
- * REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
- MTFCA Number: 23703
- MTFCI Number: 23153
- Board Member Since: 2009
The Carb looks pretty rusty. I would go with the lead gasket under the seat. I’ve had that problem before.
- Last Name: Valdes
I did the suck test. It is leaking at the elbow threads. I noticed when tightening the elbow more that the elbow threads are stripping. See picture, there is a dent in the threads at the entrance that is almost certainly stripping this out. I think the way to fix this is with a tap to realign the thread? Is there another way? Unfortunately my tap and die set doesn't seem to have the size this is. I think it is 24 pitch but unknown size.
thread is 1/8 npt. Taper pipe thread. Most sets have this tap. Being taperd, dont go to deep on the thread chase. Elbow thread looks stripped, needs replacing. Permatex aviaton or similar fuel resistant sealant works well.
The needle and seat are effectively a tap controlled by the float. As the float rises, so does the needle to close off the fuel supply at the seat. Job done.
If the "tap" still leaks fuel, the tap needs attention.
- Last Name: Tannehill
- MTFCA Number: 49460
Ignacio I enlarged the picture and it appears by way over tightening it you may have cracked the the carburetor where it threads which you may never be able to repair. Don’t ask me how I know. The thread inside are tapered and the elbow will most always will have threads exposed. Trying to get the threads of the elbow even with the carb is instant trouble. If you look closely and there is no crack you’re lucky and may be able to clean it up with a tapered tap. If not order a new elbow and perhaps a rebuilt carb unless you have one to that you can rebuild yourself. You might contact Corey Walker he rebuilds carbs for sale.
Good luck, John
Good luck, John
- Attachments
- 4E34A52C-C00D-4526-B050-8E5D89ED23C3.jpeg (74.43 KiB) Viewed 3165 times
- Last Name: Valdes
As far as I can tell it isn't cracked, just the thread is damaged. My tap set doesn't seem to have a 1/8 npt. It has a bunch of other sizes. Home Depot and Walmart seem to have them 1/8 27 npt? Is that the right one? Mail order for about $9.
- Last Name: Valdes
Oh and olive oil mouth wipe and chaser after the suck test takes the gas and fuel proof grease taste out of your mouth quick.
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 26 T Coupe, 16 T Open Express, 21 TT Flatbed. 15 T Roadster, 13 & 25 T Speedster , 51 Mercury 4 door sport sedan, 67 Mercury Cougar
- MTFCA Number: 11598
You should be able to buy a 1/8 npt tap locally. Your old elbow to carb threads are shot. The new elbow will have to come from a T parts vendor if you don't have another good elbow. Use some gas proof permatex on the threads. You may want to get from the T parts vendor a elbow with shut off to keep from having to crawl under car to use the stock gas shutoff.
Having to re-tap the thread in the carb body may be a blessing. Just clean it up first and fit the new elbow. If you have thread still showing, but the elbow is not pointing in the right direction, you can re-run the tap to let the elbow run in a little futher. It may take a few tries to get it to pint to the rear as it should.
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
Ignacio, That tap set you are showing in your pic looks to have an 1/8 tap just below the thread check gage three down from the tap handle. That is more than likely the pipe tap. Hope this helps and good luck. Jim
- Last Name: Valdes
Good eye Jim on the 1/8 if it was a snake it would have bit me!
- Last Name: Valdes
So I ran the tap through and it straightened it up some. However, it still has a little spur on it that seems perfectly placed to shred the threads on a new fuel valve I happened to have. It seems to shred it less but you can see the ribbons of brass on it. I am not sure what to do next.
Possibly your tap bottomed out before you got the thread totally cleaned. Thats a feel thing. If thats the case, you can grind a little off the tap.
- First Name: Kevin
If the modified tap doesn't work you can carefully remove the frist one or two threads in that area. Try using a deburing bit in your dremel and just slightly touch the thread.
It appears the threads are already "buggered" up on your new shut-off as if it was cross-threaded. That type of valve is known for opening/closing issues after not too long of usage - Lang's has a very nice one but you get what you pay for !
- Last Name: Valdes
The tap did bottom out. How much should I take off of the tap? The Dremel option sounds attractive.
Just enough. start with that area where there are no threads. Remember it is tapered. go in only enough to clean the thread. You may have a 1/8 pipe die in your set. Kiss the elbow thread just enough to clean its thread also.
The tap in the photo does not look tapered to my eye, which begs a question. The thread on the fuel tap is tapered, so it would bind on the thread in the carb even if the carb thread was straight, but the engagement would be narrow. If the thread in the carb was also tapered, the engagement would be made through the length of the thread, making a better seal. Does anyone else see a straight tap in the photo? If it is straight, grinding some off the end would be fruitless.
- First Name: Joseph
- Last Name: Andulics
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor, 1926 Truck, 1927 Roadster GOW, RAJO Sprint car
- MTFCA Number: 9766
For what it's worth the tap appears to be a BSP rather than a NPT. NPT/NPS and BSP threads are not compatible due to the differences in their thread forms, and not just the fact that most diametrical sizes have a different pitch. NPT/NPS threads have a 60° included angle and have flattened peaks and valleys (this is a Sellers thread form); BSP threads have a 55° included angle and have rounded peaks and valleys (this is a Whitworth thread form). Just my humble opinion. Enjoy
- Last Name: Valdes
Success! I Dremeled out the burr with a fine diamond tip. The burr turned out to be a sizable bump. It stopped shredding my elbow/valve thread. Suck test -- leak. Put some fuel resistant grease on the threads, suck test -- it held! Put the carb back on took it for a spin and let it sit for about an hour with the fuel valves on -- dry! Alright! let the fun begin. Thanks to all!
