26/27 steering box
Posted: Sun Mar 14, 2021 12:21 pm
by dmdeaton
Rebuilding my column on the beater pickup truck build and found this.
Re: 26/27 steering box
Posted: Sun Mar 14, 2021 12:23 pm
by Mark Gregush
Long pin drop into the slot to keep from over steering. That is the way they were made. If you look at the 3 pins on the shaft, one should be longer on the back side to drop into the slot.
Posted: Sun Mar 14, 2021 12:25 pm
by dmdeaton
Ok
That makes me feel better
Posted: Sun Mar 14, 2021 12:27 pm
by dmdeaton
It looks wore rather than machined. I will clean it up and try the gears
Posted: Sun Mar 14, 2021 12:44 pm
by OilyBill
Remember to keep that arc slot on the TOP when you put the steering gearbox back in the steering tube.
The actual bearing for the steering shaft is the flat area just adjacent to the hole the steering shaft fits through. It is somewhat truncated due to the arc slot, but I have never seen very much wear at that point. There really isn't very much end load on the steering shaft.
Posted: Sun Mar 14, 2021 12:45 pm
by DanTreace
Lightened up your photo. That case for the 5:1 gears seems ok. The image is at an angle, but the teeth seem good to go. Just clean out the old grease to check.
Plus rotated the picture to show how it should be in the column, driver view. The slot is up.
Here is comparison of the slot widths of the two types of cases.
late and early case with groove .jpg (43.83 KiB) Viewed 1632 times
Posted: Sun Mar 14, 2021 2:54 pm
by dmdeaton
Thanks for all the info guys
I will clean it up and start to reassemble. I’m waiting on a new shaft from Mark to get here. Old one could be welded up and turned down, which I may do as a later project. It’s chewed up pretty good near the bottom.
