Stock Ford Part Puzzle
Topic author - Posts: 3299
- MTFCA Number: 4838
- MTFCI Number: 115
For some Ford stock part fun, here’s one.
“Re: Was it ever a stock part?
Report Quote
Post by Rich Bingham » Fri Mar 08, 2019 8:08 am
Dan, what publication did that puzzle appear in, and when ? It would be a treat to see more ! (Maybe some of us could earn that $1.00 prize ! “
These Puzzels appeared in Ford Owner and Dealer in mid- 1920’s.
IF you can guess this puzzle you are indeed a Model T expert!
[/size]
Report Quote
[/size]
- MTFCA Number: 52564
Re: Stock Ford Part Puzzle
The only place I can think that would use that small of bolt/screw would be something to do with the coil box switch. Maybe as a standoff where it mount to the box.
1920 Dodge touring
1920 Dodge touring
- MTFCA Number: 14972
- MTFCI Number: 15411
Starter ring gear indexer to flywheel.
Steve, I think that is correct. Tend to forget about those, they are so few and far in between.
1920 Dodge touring
1920 Dodge touring
- First Name: Rich
- Last Name: Bingham
Thanks for that Dan !!
These are great ! I hope you can post many more of them. Lots of fun !
"Get a horse !"
- MTFCI Number: 115
Steve can be known as one of the “experts”!
His reply is correct on those little collars.
- First Name: Thomas
- Last Name: Petry
Hasn't changed after all these years. The factories still look at two cent parts that can be done away with to save a eight cents per car. It adds up over the number of cars they build each year. It would almost make sense if not for the fact that they will replace a simple push pull cable to open an air vent with a computer operated electronic switch and an electric motor to open the valve and if anything goes wrong with the system you need to replace hundreds of dollars of parts when the cable would cost ten bucks.
I may be living in the past, but I can still diagnose problems with a points and condenser ignition on the side of the road and fix it without a computer to tell me what parts to replace.
- First Name: Duane
- Last Name: Cooley
- MTFCA Number: 32488
Well said Thomas. The money I've spent on our near 250,000 mile 2011 on electronic bits, light bulbs, actuators and fuses...
That was really neat Dan! Thank you. That was fun!
- First Name: Daren
- Last Name: Carlson
- * REQUIRED* Type and Year of Model Ts owned: 1925 Tudor
Two cents each...Add the additional machining cost of the flywheel and ring gear to that.
