Stock Ford Part Puzzle
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Mar 08, 2019 9:25 am
For some Ford stock part fun, here’s one.
“Re: Was it ever a stock part?
Report Quote
Post by Rich Bingham » Fri Mar 08, 2019 8:08 am
Dan, what publication did that puzzle appear in, and when ? It would be a treat to see more ! (Maybe some of us could earn that $1.00 prize ! :D
These Puzzels appeared in Ford Owner and Dealer in mid- 1920’s.
IF you can guess this puzzle you are indeed a Model T expert!
[/size]
Last Name: Gregush
MTFCA Number: 52564
Re: Stock Ford Part Puzzle
Post by Mark Gregush » Fri Mar 08, 2019 10:21 am
The only place I can think that would use that small of bolt/screw would be something to do with the coil box switch. Maybe as a standoff where it mount to the box.
1920 Dodge touring
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Fri Mar 08, 2019 10:28 am
Starter ring gear indexer to flywheel.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Fri Mar 08, 2019 10:39 am
Steve, I think that is correct. ;) Tend to forget about those, they are so few and far in between.
1920 Dodge touring
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Fri Mar 08, 2019 2:05 pm
Thanks for that Dan !!
These are great ! I hope you can post many more of them. Lots of fun !
"Get a horse !"
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Mar 08, 2019 3:47 pm
Steve can be known as one of the “experts”!
His reply is correct on those little collars.
46woodduck
First Name: Thomas
Last Name: Petry
Post by 46woodduck » Fri Mar 08, 2019 7:09 pm
Hasn't changed after all these years. The factories still look at two cent parts that can be done away with to save a eight cents per car. It adds up over the number of cars they build each year. It would almost make sense if not for the fact that they will replace a simple push pull cable to open an air vent with a computer operated electronic switch and an electric motor to open the valve and if anything goes wrong with the system you need to replace hundreds of dollars of parts when the cable would cost ten bucks.
I may be living in the past, but I can still diagnose problems with a points and condenser ignition on the side of the road and fix it without a computer to tell me what parts to replace.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Fri Mar 08, 2019 9:25 pm
Well said Thomas. The money I've spent on our near 250,000 mile 2011 on electronic bits, light bulbs, actuators and fuses...
That was really neat Dan! Thank you. That was fun! :)
daren007
First Name: Daren
Last Name: Carlson
* REQUIRED* Type and Year of Model Ts owned: 1925 Tudor
Post by daren007 » Fri Mar 08, 2019 11:17 pm
Two cents each...Add the additional machining cost of the flywheel and ring gear to that.
