Headlight Gas Line Routing
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Mar 09, 2019 10:31 am
I've not been able to see a untouched car to verify my question, so maybe someone can tell me how FORD did this? I have my gas line ready to mount today, and want to know which side of the steering column wood block it goes on. I should know this, but there are few folks out there running gas lights.
BHarper
First Name: Bill
Last Name: Harper
MTFCA Number: 5414
Re: Headlight Gas Line Routing
Post by BHarper » Sat Mar 09, 2019 11:09 am
Hi Larry,
First, I will state that I do not know. The picture below does not show that detail.
One can see that the line does sit inside the frame as it runs forward from its clamp, but the area of the wood block is not in the photograph.
This pictures suggests that the gas line is routed between (or UNDER ???) the wood block and the frame.
Not knowing the sequence of assembly at the plant, we can only guess (using Good Manufacturing Process) WHEN something as long and fragile as the gas headlamp line was installed on the chassis, after the engine but before the steering column? Who knows. Early cars, without the holes in the radiator for the gas hose, apparently had the gas line run below the frame, as shown in these pictures.
What year are you working on, Larry? Your '13? Good luck with your project, Bill
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Sat Mar 09, 2019 1:40 pm
Hi Larry,
Here are some pictures of my unrestored 13 Touring showing the gas line for the headlights running under the wood block at the rear engine mount.
Then it runs under the wood block for the steering mount.
Hope this helps.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Sat Mar 09, 2019 5:01 pm
Bob-
That would have been my guess, but Larry was looking for Ford facts, not a guesses.
Larry-
Does the print show the gas line as straight up by the radiator, or a curve, as Bob's shows?
So are there then three short lengths of rubber hose, one going to the bottom of the cross over tube T, than two other that go to each headlamp?
I look forward to seeing pictures.
Keith
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sun Mar 10, 2019 9:52 pm
Thanks for the photos! I think someone has altered the gas line in these photos. I just need to know if the gas line runs along the inside of the frame right up against the rail, or does it start tapering inside, but still next to the two steering column bolts? This is about as trivia as it gets, but that is what I like! That line can actually be on either side of the two bracket bolts, but still be inside the frame.
Erik Barrett
First Name: Erik
Last Name: Barrett
Post by Erik Barrett » Mon Mar 11, 2019 1:01 am
If you are using an acetylene gas generator, be advised that they put out a lot of water with the gas. If you have dips and low spots in the lines, water will gather there and you will soon be in the dark.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Mon Mar 11, 2019 10:05 am
The last two photos Bob posted are what I was after. It clearly shows the tubing going on the right side of the two steering column bolts, but still under the wood block. Actually, it makes more sense to do it this way, because the tubing will line up better with the Tee on the radiator.
Post by Scott_Conger » Mon Mar 11, 2019 3:36 pm
A word of caution to someone contemplating installation of NEW lines for their functional Acetylene headlights: do NOT use copper or brass tubing containing a high copper content. Copper Acetylide can be produced which is a shock-sensitive (explosive) compound. Not that I would imagine anyone would do it, but the same goes for acetylene's reaction to silver or mercury.
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Mon Mar 11, 2019 5:32 pm
Hi Scott,
Is this really an issue? The vendors all sell the headlamp gas-line kits with copper tubing. What kind of tubing was used originally?
Long ago, when I was messing about with chemistry, I made a batch of silver acetylide. The silver was put into solution in hydrochloric acid and acetylene was bubbled through the silver solution. The silver acetyide precipitated out as a "salt" and collected at the bottom of the beaker of solution. The resulting silver acetylide was quite explosive, much more so than black powder. The SA crystals go bang when ignited or under impact without any containment like firecrackers.
That said, I don't see how exposing silver (like the silver dime that was sacrificed to the aforementioned experiment) to gaseous acetylene would create acetylide, but I could be wrong. I do agree that one should not run acetylene though a copper solution, but using copper piping shouldn't end in the same results.
Keep crankin'
Eric
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Mon Mar 11, 2019 6:24 pm
Eric, I can't speak for all parts suppliers, but the line I bought from Lang's is brass. The metallurgy of the seamless tube is probably un-knowable, hopefully the copper content is at a suitable proportion for the purpose.
That copper acetylide can and does precipitate in lines and vessels carrying acetylene generated at will by water and carbide is a fact which was cautioned against early on in the mining industry and later through the automobile gaslight era. I don't think it's a huge issue for restorers if lamps are plumbed in as per original, but I'd stay away from using copper lines.
To second guess the question, "then why are all my oxy-acetylene welding tips copper ?" Apparently the answer is that unlike your automobile headlamps, the gas is mixed with oxygen. Personally, I'd like to know more about this.
"Get a horse !"
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Mon Mar 11, 2019 6:46 pm
here's the link to the kit sold by Langs:
https://www.modeltford.com/item/BL-T.aspx
Their description : This complete hook includes the copper tubing, copper T fitting, red rubber tubing, brass hose clamps, and instructions.
Here's the link to the kit at Snyder's:
https://www.snydersantiqueauto.com/hook-up-kit
Their description: For the gas headlamps this kit includes 8' of copper tubing copper 'T' fitting 3' of red rubber tubing, and six brass clamps. U.S.A.
So that's what is out there today. Does anyone know what the hard tubing was made of originally?
Keep crankin'
Eric
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Mon Mar 11, 2019 6:52 pm
Bought mine about 18 months ago. It's brass. I wonder why they would switch to copper ?
Some time back "original" Smith told us the original lines were tin plated brass.
"Get a horse !"
Post by Scott_Conger » Mon Mar 11, 2019 8:41 pm
I'm sure the copper is of course OK for "show", assuming you're not concerned with originality, but simply ease of fabrication. However, using it with a functioning system is a definite NO-NO. I think the amount and frequency of use probably places this in the "low probability" area, but chemically, it is playing with dynamite...no pun intended. If there was ever an explosive event with a T with copper tubing that was sold by a vendor as fit for use with acetylene, I would not want to be on the supplier end of the lawsuit, given the plethora of information available to a good lawyer.
https://www.haunweldingsupply.com/documents/61.pdf
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Mon Mar 11, 2019 11:44 pm
Ok, per the msds “Advice on safe handling: Never use copper piping for acetylene service. Only steel or wrought iron pipe should be used”. In 2003, Brown University issued the following safety alert “Recently, the Office of Environmental Health & Safety (EHS) identified a research laboratory using copper tubing to transport acetylene gas into various pieces of equipment. According to multiple resources and the Material Safety Data Sheet (MSDS), acetylene (C2H2) is known to form very explosive metallic salts when exposed to metals such as copper, silver, mercury, and brass with high (65% or more) copper content. Utilizing copper tubing or regulators not manufactured specifically for acetylene use poses a severe risk to laboratory personnel. The Office of Environmental Health & Safety recommends that all persons using acetylene gas inspect their systems to ensure that the regulators are manufactured for acetylene and that copper tubing or brass fittings are not in use. Stainless steel tubing is recommended.”.
Given that brass tubing with less than 65% copper is uncommon, it would make sense to me that any T gas lamps that are used regularly should be piped with steel or skip the hard pipe altogether and run all rubber hose. Another option would be copper tubing with coated interior (available from mcmaster-carr) that is lined with 99% pure tin, but then we’re back to copper, not brass for originality. This “coated interior” may be similar to what was referred to as “tin plated” by Smith. I was not able to find a source for brass tubing with coated interior.
Brass for casting that is 60% or less copper is more common, although more brittle than the higher copper alloys used in most tubing. Are we confident that the other available brass lamp fittings, i.e. burners and elbows, are made from an appropriate alloy?
I am now convinced that the copper tubing that was provided in my “hook-up kit” should not be used. Since none of us should be adding any more “built-in” danger to our T’s, what would the general consensus be to restoring a functional gas lamp system?
Keep crankin’
Eric
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Mar 12, 2019 12:38 am
I had my local radiator shop attach the new gas line to the radiator. I made the radiator gas line, and the frame gas line according to the original Ford prints for '13 and '14. Yes, the original material was brass, and in 1913 they specified tin plated, AND, they double flared the ends of the pipes for a total five flares. Prior to 1912 there were no flares, and no tin plating. I couldn't find a plater in my area that would do tin for a reasonable price, so I had it cad plated instead. I just wasn't up to spending $150 to tin plate those tubes! Judging from the most recent photos of the original untouched '13, I'm going to route my frame tube along the right hand side of the two bolt heads, and the steering support bracket. Unfortunately at this point there is NO correct red tubing for Model T's, which require 7/16". I spoke with Ron Gocek at Hershey last year and mentioned that he had it made the wrong size last time, 5/8". That just won't do! The hole in the splash shield is 7/16" which is what Ford specified. 1/2" will fit through the radiator holes, but not real well through the splash shield. Ron is aware of the problem, and I hope he will solve the problem for us soon. Enough raging for now.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Tue Mar 12, 2019 12:52 am
Larry-
I look forward to seeing pictures of your project.
- Keith
Bob McDaniel
First Name: Bob
Last Name: McDaniel
MTFCA Number: 28428
Post by Bob McDaniel » Tue Mar 12, 2019 12:58 am
I am going to toss this into the fire here and see what happens. What about all the brass carbide generators from who knows when up to 1912? If brass is a problem then how did they not blow up?
Just a thought and worth what you paid for it. :roll:
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Tue Mar 12, 2019 12:46 pm
A number of years ago I made a new 44" long "gas lamp tube assembly, rear" used on our T's from July 1912 until the end of gas head lamps. If your 1912 radiator had gas tube holes in the side panels and a cross-over, you had the rear gas tube Larry started this thread about. For mid-1912 thru 1914 gas lamps, it is the only metal part we can make unless you remake the radiator cross-over.
The "flares" on the two ends of the rear gas line look like the detail that R.V. posted of the 1/4" OD tube cross-over on the radiator (below).
I used K&S Metals 1/4" OD tube from the hardware store. It and the 9/32" tube I made the sleeves from is 260 and if I made another one, that is what I would use.
I use a Prest-O-Lite tank because I drive the car at night and can light up in less than two minutes. Drove the 1914 to the barber shop Saturday morning at 5:30a.m. If you use a POL tank and "crack" the valve, I would suggest leaving off a rubber tube clamp at one of the elbows or tank.
Also, the NOS Colt burners & inside screens, Victor stands and elbows are brass on my setup too. I'd be between a rock and a hard place for gas lamps if I didn't use brass.
Post by Scott_Conger » Tue Mar 12, 2019 1:27 pm
Bob McDaniel
well, we know a few more things now than in 1912. I have set my copper acetylene lines on a shelf right next to my arsenic animal dip, my asbestos insulation, and radium watch and clock dials.
BTW, I doubt that the danger of acetylene lines were completely unknown in the day. Why do you suppose that the brass lines were tin plated? With the necessity of constant cleaning of the generators, the explosive salts did not likely have time accumulate, and while I am NOT an expert in acetylene generators, I do own a couple on cars, and I seem to recall that the interiors were tin plated, too (I could be relying on faulty memory on that and they may just be dirty).
Today's replacement parts from copper are done out of simple ignorance of the chemistry by the supplier, I am sure. It's neither correct from a restoration standpoint, nor safe for actual use. That's not a statement of my opinion; it's a recognized fact. I would concede an argument made that our use is (generally) so seldom, that these compounds may not have sufficient time/exposure to develop. But the fact remains that exposure of copper or brass of a high copper content to acetylene is a danger known to the government, chemists, and industry. Not knowing about it in our hobby does not change chemistry or keep us safe.
So, be safe! :)
Post by Scott_Conger » Tue Mar 12, 2019 1:39 pm
Kenneth
"Brass" is not a problem. Brass with Cu % equal to or higher than 65% is a problem.
C27200 GENERAL PURPOSE SEAMLESS BRASS TUBE (ASTM B135) is 62-65%. Not (likely) a problem
C38500 Free cutting brass for fittings 56-60%. Not a problem.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Mar 12, 2019 3:54 pm
Thank you for that detail Scott !
"Get a horse !"
Bigal
First Name: Alan
Last Name: Stein
MTFCA Number: 7916
Post by Bigal » Tue Mar 12, 2019 5:03 pm
I have a late 1911 Touring and am looking for the brass "T", "elbow, and "inline sleeve/nipple". Does anyone out there reproduce these? I searched old forums and found that at one time Kim Dobbins and a George made them. I emailed them both and have not received any reply. Maybe to long ago.
If anyone can provide a lead I would appreciate it. You can contact me at astein.pls@gmail.com or 586-243-7202. Thank you. Al, MTFCA #7916 and MTFC #9631
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Tue Mar 12, 2019 6:07 pm
This is what I found on "260" brass. "260 Brass (also known as cartridge brass or yellow brass) - the most popular and economical of the brass alloys. Chemical Composition
Copper: 68.5%-71.5%
Iron: 0.05%
Lead: 0.07%
Zinc: 28.5%
Other: 0.15%"
This is consistent across a number of metal suppliers that list their alloy composition. 230 brass, 260 brass and 330 brass are all above the 65% copper threshold, the alloys 260 and 330 have better workability for forming and are therefore used for most brass tubing and piping. It's pretty easy to see that these brass alloys should now be considered inappropriate for use in gas headlamp systems.
360, 464, and 770 brass alloys are all under the 65% copper threshold, these alloys are better suited for machining rather than forming.
All of this points to the fact that for this discussion, brass may or may not be ok, depending on the specific alloy used. I don't know how to determine what alloy was used for a given fitting if not stated by the manufacturer/seller. But it obviously pays to do one's research.
Keep crankin'
Eric
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Tue Mar 12, 2019 8:09 pm
Hi Rich,
I looked at my copy of the Lang's 2012 catalog and the BL-T Gas Headlight hook up kit on page 121 lists the parts as "copper tubing, copper T fitting, red rubber tubing, brass hose clamps, and instructions". The listing has been consistent for at least 7 years, so I think that it is likely that your kit came with copper tubing unless you special ordered it
My 2005 Chaffin's catalog lists a copper T fitting as well. It looks like the vendors have been supplying copper gas hook ups for more than 10 years.
Keep crankin'
Eric
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Mar 12, 2019 8:42 pm
Hi Eric, you are certainly correct about Lang's catalog offering. I guess where I went astray was in not ordering the "kit". From the online catalog, I ordered 44" of brass tubing . . . to run acetylene. I ain't too bright, but I can usually tell copper from brass. The kit offered shows a coil of what appears to be soft copper tubing, and describes a "copper tee". Sure hope no one has a bad reaction from its use.
"Get a horse !"
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Tue Mar 12, 2019 9:37 pm
Apparently I ain't too bright. I can't find any sort of this size of brass tubing in Lang's online or printed catalog, or any of our other regular vendors either.
Since my fall back of McMaster-Carr only sells brass 260 tubing, I should just push this project back and focus on other T projects instead.
Eric
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Tue Mar 12, 2019 9:54 pm
Eric, this thread is the first discussion I've found that identifies different brass alloys by copper content. I bought that rigid line in blissful ignorance, and of course I have no idea what alloy it is. If all you've found is 260, that's probably what I have. Alaskan Copper & Brass in San Diego used to be a good source, but any more it's getting hard to impossible for us restorers to get small quantities of many materials for projects. Keep searching, if enough of us are on the lookout for items we need, I'm sure something will turn up !
"Get a horse !"
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Wed Mar 13, 2019 4:07 pm
So just in case I come across the appropriate brass tubing in reasonable quantities, are there any dimensions/diagrams for the 2 pieces, the mostly straight piece that runs forward in the frame and the radiator crossover tube for radiators with gas tube holes in the side panels with the tee fitting and lightly bent ends.
It should not be much extra effort to make multiple sets to use up a minimum order quantity compared to making just one personal set and keeping the extra material on a shelf.
Keep crankin'
Eric
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Wed Mar 13, 2019 6:21 pm
I don't know when they went to the 1913-14 system, but guessing I'd sometime in late '12. The original print listed above shows the new design, with, the double flares used in '13 & '14. I bought my brass tubing from McMaster Carr, and it arrived the next day in a nice stiff tube. There was enough for the frame, and radiator gas lines with some left over. I bought the 6' length. I have it almost done, except I now need to get some work done on the radiator, which wasn't soldered very well on the drivers side.
The red tubing is the issue now. It is NOT made to Ford specifications, and will not work for a '13-14 because it is 5/8"dia. I suppose it will work for a pre 1912, but maybe not. The hole in the splash shield for my '13 is 7/16", and a 5/8 tube won't fit!
Ron Gocek is aware of the issue, but when he will get around to correct the problem is anyone's guess.
ewdysar
First Name: Eric
Last Name: Dysart
Post by ewdysar » Wed Mar 13, 2019 7:02 pm
OK. Does anyone know how I can see a copy of the original print?
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Sun Mar 17, 2019 7:09 pm
When I installed this line it was on the best information available at the time. I see from period photos above (and others of original cars) I've likely got it all wrong. :oops: so the line is supposed to run inside the frame rail, under the pan arm blocks, and under the steering column bracket but outside the bolt heads ? This is a '13 with the "tee" and cross pipe soldered to the radiator.
"Get a horse !"
Drkbp
First Name: Kenneth
Last Name: Parker
Post by Drkbp » Mon Mar 18, 2019 11:04 am
If using carbide, you may want to run the rear gas line as discussed above when you get a chance.
Keeps the moisture trap at the splash shield hose.
Do you have the frame clamp?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Mar 19, 2019 10:23 am
I still don't have my new system intact yet. I discovered my new Brassworks radiator wasn't soldered properly, so it's at the radiator shop now. I really lucked out on the red rubber tubing. I had to buy a kit from a guy who never used his, and the tubing is 1/2". I'll get some photos soon. I learned from a guy who uses his headlights frequently, it's a good idea to detach the gas line somewhere when not in use to vent the system. As far as the brass Tee goes, my partner has the pattern for the Tee. When he will get around to having them made is anyone's guess! Perhaps the reason Ford started tin plating the tubing is they switched to seamed brass tubing. Perhaps the tin plating may help seal the seams? Lastly, a gentleman approached me at Chickasha with part of the radiator tubing in his hand with the Tee attached. It was tin plated.
richc
First Name: Rich
Last Name: Chillingworth
MTFCA Number: 30527
MTFCI Number: 23207
Post by richc » Tue Mar 19, 2019 10:51 am
Here is the original plated tee Larry referred to.
Rich C.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu Mar 21, 2019 9:26 am
Thanks for posting Rich. These photos are important, and yes that is the Tee we are planning to make. The O.D. of that Tee is 3/8, and of course, the I.D. is 1/4.
Fordfarm
First Name: Phil
Last Name: Mino
MTFCA Number: 1599
Post by Fordfarm » Fri Mar 22, 2019 4:08 am
While you are at it, Larry, how about making some of these?
KimDobbins
First Name: Kim
Last Name: Dobbins
MTFCA Number: 8243
Post by KimDobbins » Fri Mar 22, 2019 7:20 am
Larry, I did some machine work for a friend who works for a Chinese company that does small run casting. I'll see if they do brass. Also you can check with Dennis Oley when we are at Bakersfield. He has small runs done is Oregon. Kim
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Mar 22, 2019 11:11 am
Sorry I haven't posted pictures yet. I'm currently working on a pair of new hood boards for the front fenders. My originals needed replacing. As soon as I get those installed I'll finish up the gas line routing and submit some photos.
