1926 Roadster Trunk Lock
Topic author - Posts: 47
- First Name: Randy
- Last Name: Clemens
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster Pickup, 1926 Roadster, 1927 Fordor
Does anybody know how to deal with a inoperative trunk lock on a 26/27 Roadster? Cant get the trunk open..... I have tried all I can think of without causing damage.
- Last Name: House
- MTFCA Number: 115
Re: 1926 Roadster Trunk Lock
I’ve removed the trunk lock on my ‘26 roadster by removing the 4 little screws. Otherwise I’d have to use the key to pull the trunk lid open after I unlock it. Now I just open it with the tips of 8 fingers. Don’t keep any valuables in the trunk anyway.
I don’t know why I turned out this way. My parents were decent people.
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
Just press down hard when you inset the key and turn it counter clockwise.
You will surprise yourself!
- First Name: Randy
Thanks guys, tried the press down hard advice but it’s tight against the body....it has nowhere to go.
- MTFCA Number: 14972
- MTFCI Number: 15411
Did it work before and this a new problem ?
- First Name: Bill
- Last Name: Mullins
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster 1927 Tudor
- MTFCA Number: 20750
- MTFCI Number: 19613
If the pin that guides the key is broken or loose I have used a 90 degree pick to trip the latch.
- First Name: Jim
- Last Name: Riedy
- MTFCA Number: 25079
- MTFCI Number: 18732
Sometimes if I'm feeling lazy and don't want to grab the keys I just grab the top of the spare tire and give it a tug to the rear while lifting upward on the deck lid. If this works for you then you can work on the latch, mine was froze solid with rust and I had to drill out the rivets that hold it together. If I remember correctly the screws go through the rivets. Good Luck Jim
- First Name: Randy
Thanks everyone. I dont have a rear tire mount the car so nothing to pull on. I am thinking now I might have to go up through the battery opening and push with something - similar to pulling on the tire mount? This one has me puzzled.
- First Name: Vernon
- Last Name: Worley
- MTFCA Number: 49462
The last lock I had that would not turn with a key, I worked it free with some transmission fluid by first dipping the key and then inserting into the lock.
Vern (Vieux Carre)
