motor rebuild problems
Posted: Thu Apr 01, 2021 6:45 am
by NU2theT
Got the motor back from the builder and I can't set the commutator rod to the timer that now looks like a football.
To make matters worse the motor won't fit with these 4 extra cylinders, any input would be great.
Re: motor rebuild problems
Posted: Thu Apr 01, 2021 8:10 am
by TXGOAT2
That's a common problem with older Fords ... cylinder proliferation. It often happens with oldedr engines that have not been properly stored in a cool, dry place. It can usually be reversed by placing the engine in a slow oven at 270 F for 8 to 12 hours. Many people report that basting the engine every half hour during baking with Hadacol gets the best results. After baking, serve with '32 frame on a bed of red cabbage. (From Martha Stewart's "How to Hop-up Your Ford")
Posted: Thu Apr 01, 2021 8:15 am
by John Warren
Sweet, nothing sounds like a flat head ford V8. They have heating problems, easy fix, those two pumps just moved the water way to fast!
Posted: Thu Apr 01, 2021 10:36 am
by John Codman
We used to race a flathead as a stock car. As was said, the two pumps just moved the water too fast - we did not run thermostats, we just couldn't make it cool with them. The solution was to remove half the blades in the water pumps; it sounds counter-intuitive, but it worked!
Posted: Thu Apr 01, 2021 10:50 am
by Norman Kling
It looks like your engine went into labor and produced conjoined twins!
Posted: Thu Apr 01, 2021 11:01 am
by Les Schubert
A V8-60 will fit in nicely!! A friend of mine is building one!
Posted: Thu Apr 01, 2021 12:32 pm
by Chuck Regan
Take it back to Mercy Hospital - your baby got switched!
Posted: Thu Apr 01, 2021 1:15 pm
by kmatt2
Many street rodder owned Model T's have Model T's that think they were really born as Chevy's . Model T's that self identify as Chevy's require small block Chevy engines. Have a good April Fools Day.
