Starter Repair
Topic author - Posts: 121
- First Name: Brendan
- Last Name: Doughty
- * REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
- MTFCA Number: 15143
Starter Repair
Has anyone had any luck soldering a loose terminal bolt to the buss bar without removing it form the buss bar to clean it? How have you been repairing them without replacing the assembly.
- First Name: Andy
- Last Name: Loso
- MTFCA Number: 346
- MTFCI Number: 119
Re: Starter Repair
It can be done, if it is clean. It is already loose though so why not just remove it and prep it right? I have seen many of them, where the pin has pulled through the buss bar anyways, so you have to replace it anyways.
- MTFCA Number: 14383
Re: Starter Repair
If pin is intact, bend stud/ribbon out to remove washers. Sometimes a squeeze with channel locks will tighten. I use an oxy/acetylene torch super small tip set to a small neutral flame. Concentrates a hot flame to that specific area. Warm & hit with ruby red solder flux to clean & then flow in solder.
As mentioned, if stud has pulled thru ribbon, replace ribbon.
- First Name: Kenneth
- Last Name: Todd
Re: Starter Repair
Use lead free solder, makes a stronger joint.
