Starter Repair
Posted: Fri Apr 09, 2021 5:20 am
by Plankhill
Has anyone had any luck soldering a loose terminal bolt to the buss bar without removing it form the buss bar to clean it? How have you been repairing them without replacing the assembly.
Re: Starter Repair
Posted: Fri Apr 09, 2021 8:03 am
by Andy Loso
It can be done, if it is clean. It is already loose though so why not just remove it and prep it right? I have seen many of them, where the pin has pulled through the buss bar anyways, so you have to replace it anyways.
Re: Starter Repair
Posted: Fri Apr 09, 2021 8:35 am
If pin is intact, bend stud/ribbon out to remove washers. Sometimes a squeeze with channel locks will tighten. I use an oxy/acetylene torch super small tip set to a small neutral flame. Concentrates a hot flame to that specific area. Warm & hit with ruby red solder flux to clean & then flow in solder.
As mentioned, if stud has pulled thru ribbon, replace ribbon.
Re: Starter Repair
Posted: Fri Apr 09, 2021 11:13 am
by katy
Use lead free solder, makes a stronger joint.
