Stromberg passage plugs
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 13, 2021 2:13 pm
Carb runs great on new engine start, but dribbling a little fuel from the passage screws. They were a little loose but don’t want to snug them in until I ask. Not tapered and nothing to seal on the lip. I am thinking a touch of pipe dope maybe.
MTFCA Number: 52564
Re: Stromberg passage plugs
Post by Mark Gregush » Tue Apr 13, 2021 2:27 pm
never mind
1920 Dodge touring
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 13, 2021 2:30 pm
I snugged them up a little more and I think the dribble stopped. I was being too careful and anal. 😳
StanHowe
First Name: Stan
Last Name: Howe
MTFCA Number: 19133
Post by StanHowe » Tue Apr 13, 2021 3:46 pm
DO NOT put pipe dope on them. Those are called grub screws. They tighten again the edge of the hole. Allen head screws have nothing to tighten against and need a washer. If you really think you need something on them a little swipe through Ivory soap is the best thing you can use.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Tue Apr 13, 2021 5:22 pm
I understand that but the burr needs to knocked down also or it doesn’t have a flat surface for the edge of the small collar on the screw to seat against and seal. I deburred the threaded hole surface and snugged it down and all is fine. The burr was keeping it from seating 100%.
