Another ammeter question
Topic author - Posts: 85
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
I wired my 26TT according to Ron Patterson's diagram. It is 6v negative ground with a voltage regulator. It is not running yet but when I turn on the lights the ammeter pegs to the right (charge). What do I do?
- Last Name: House
- MTFCA Number: 115
Re: Another ammeter question
Reverse the 2 ammeter wires. You got em crossed
I don’t know why I turned out this way. My parents were decent people
- MTFCA Number: 14383
yes, wired backwards. "Pegging" ammeter? Sounds like a short.
- Last Name: Zibell
- MTFCA Number: 30265
- MTFCI Number: 24046
Reproduction ammeters for the 26/27 model years are cheap junk. They are no where near close to reading correctly. When I purchased my voltage regulator from John Regan he was kind enough to loan me an accurate ammeter to adjust the third brush. So that said, find an accurate ammeter and hook it up between the regulator and line when adjusting the third brush IAW the instructions provided with the regulator. Also it is important to make a fine adjustment the next day as outlined in the instructions.
1926 Tudor
- MTFCA Number: 121
- MTFCI Number: 16310
I'm confused! Most TT's in 26 & 27 still use the earlier style dash panels, but I have seen closed cabs with the passenger style. What is it?
- MTFCA Number: 14972
- MTFCI Number: 15411
Larry - I've not seen any open cab TT's with the "Improved" passenger car style switch plate but I have seen later closed cab TT's with the passenger car type and the dash has the oval cut-out rather than the square one as most '19 to '25's passenger cars sport.
- MTFCA Number: 4838
- MTFCI Number: 115
Here's two different closed model TT's, late models, with the Improved Car oval switch plate. Ford did these
If the ammeter in question is a new reproduction small '26-'27 type, these are Model A meters, with special 20-20 faceplates, and the Model A is positive ground, so you have to switch the wires at the terminal posts on the rear of the meter, for Model T negative ground. They just don't make both anymore.
I have a "depot hack style" lnstrument mount with the 26-7 style cutout. Is that what you mean? Its stamped steel, a little bigger than the switch assembly . I think they were on TT's, not the style full dash as pictured.
- MTFCA Number: 52564
They are talking about the small panel that the light/ignition and amp meter mount to, not the bent bracket that it attaches to in your case. This would be the 1919 to 1925 car style and sometime in to 1926 TT style; http://www.mtfca.com/discus/messages/41 ... 1414604498
1920 Dodge touring
1920 Dodge touring
- First Name: Rod
- Last Name: Petrie
My switch plate is like the second picture and i have a repro ammeter. If the ammeter is Model A this explains the need to reverse the wires. I did reverse the wires and it now reads correctly. Thanks for the help.
