Ford Faithful Oil System
jimuris
Last Name: Pakuris
* REQUIRED* Type and Year of Model Ts owned: 14,24 TOURING 15 OPEN EXPRESS
MTFCA Number: 11834
MTFCI Number: 24653
Post by jimuris » Sun May 02, 2021 8:33 am
Hello does anyone have one of these kits on their car . Not to much information out there on them. Want to know if it's a good investment.
Last Name: Gregush
MTFCA Number: 52564
Re: Ford Faithful Oil System
Post by Mark Gregush » Sun May 02, 2021 9:48 am
Doing a google search of "mtfca; Ford Faithful" there are lots of entries from post on this forum, these should help;
https://www.google.com/search?client=fi ... d+faithful
1920 Dodge touring
jimuris
Last Name: Pakuris
MTFCA Number: 11834
MTFCI Number: 24653
Post by jimuris » Mon May 03, 2021 7:32 pm
Thank's a lot that's quite a bit of info.
Susanne
First Name: Susanne
Last Name: Rohner
MTFCA Number: 464
Post by Susanne » Tue May 04, 2021 6:03 pm
I have one, it's a better system (IMO) than the original Ford internal line IF YOU KEEP YOUR LINES TIGHT, mine flows a LOT of oil to the front of the motor... after running it I can't see a reason NOT to... it's like free oil for the front of your pan!
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue May 04, 2021 9:43 pm
I will be putting one on my 25 when I pull the engine. I will not be using the attachment to bottom of the inspection plate, will be plumbing it in to side of pan in about the same area.
1920 Dodge touring
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue May 04, 2021 10:45 pm
I plumb mine through the pan - makes it much easier to remove the lower cover for maintenance !
