help with valve clearance
Emeraude
Last Name: Loranger
* REQUIRED* Type and Year of Model Ts owned: 1921 touring
MTFCA Number: 32239
Post by Emeraude » Mon May 03, 2021 6:22 pm
I just bought a 1925 roadster that had not run in 10 plus years. The first thing I did was a compression test and all 4 cyl were at 25 lbs. I I then did a leak down test and did leakage from both the intake and exhaust but none thru the crankcase. I preperation to do the valves I researched the forum and found a post in 2010 by glenn chaffin where he described bring each valve to tdc then rotating 360 degrees and checking valve clearance. I did this on all the valves and found the clearances within specs. Another source describes bringing the piston to tdc then setting the clearance. When I brought #1 to tdc there was no clearance .
My question is,which is the proper way, glenns or the second? On the second way I would have to grind down the stem (i do not have adjusable lifters) so I am hesitent grinding them until I get some advise
Re: help with valve clearance
Post by Scott_Conger » Mon May 03, 2021 6:41 pm
The "other source" assumes it is on compression stroke. You have it on exhaust stroke and intake is starting to open, thus the no clearance.
In any event, it doesn't matter. Your compression appears to indicate worn valve seats and if that is the case, you need to do a valve job before you are worried about valve clearances (particularly since you've already established that they are in spec).
HOWEVER:
All that said, if the car has sat for 10 years, you should be able to get it fired up and you may be very pleasantly surprised to find that within a month of driving, compression is up considerably from where it is. DO NOT PULL THE HEAD just to see what's inside...I'll tell you: a bunch of black carbon...now you don't have to look. Just start it and drive it a bit after you've done a safety check. After sitting for 10 years I think 25 pounds compression is pretty good. Once rings reseat and valves snap the old gunk off of them you may well have a driver with no further engine work.
NH Full Flow Float Valves
Kerry
Last Name: van Ekeren
Post by Kerry » Mon May 03, 2021 6:52 pm
Still got the original 2 piece valves?
MTFCA Number: 14383
Post by speedytinc » Tue May 04, 2021 8:34 am
Scott's thought on running it is a good one. Squirt a little ATF into the cylinders & run it. Compression likely will come up. Nothing to lose either way. Then assess if you need a valve job and or rings by new compression readings.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Fri May 07, 2021 7:42 pm
The real problem with compression that low is that you cannot create enough suction to suck in any gas charge.
I had a 1950 Ford like that, if it sat long enough (about two weeks) to drain all the oil off the cylinder walls, it could not get any gas to fire.
I had to remove two spark plugs and add a shot glass full of engine oil followed by a shot glass full of gasoline.
Firing on two cylinders would give enough engine speed to suck in some gas on the other cylinders.
Then it would run fine, but just did not have a lot of power.
