1914 Roadster Top
John Haynes
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1910,1911,1912,1913.1914
MTFCA Number: 27737
1914 Roadster Top
Post by John Haynes » Wed May 05, 2021 2:59 pm
I am working on a 1914 Roadster top and I have a question. This relates to the rear top bow position. Is it exactly above the rear seat back or does it go back farther than the seat back, and if so how far back? I know on the touring bodies I have seen the back bow is a few inches farther back than the back of the seat. I am not sure if the Roadsters are the same in that regard. I would appreciate any input.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Re: 1914 Roadster Top
Post by ThreePedalTapDancer » Wed May 05, 2021 3:20 pm
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed May 05, 2021 5:16 pm
John,
The back of the top follows the trajectory of the body. The image shows a 1915-1922 top, but only the front bow is different.
Keith
John Haynes
Last Name: Haynes
MTFCA Number: 27737
Post by John Haynes » Wed May 05, 2021 6:52 pm
Thank you Keith!
John Haynes
Last Name: Haynes
MTFCA Number: 27737
Post by John Haynes » Thu May 06, 2021 9:37 am
Thank you Ed!
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Thu May 06, 2021 11:02 am
That diagram above is no 1914!
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu May 06, 2021 11:51 am
John,
Don't forget to add the "wedge" on the last bow.
Do a search of old forums to see details...
Keith
modeltspaz
Last Name: Spaziano
MTFCA Number: 21699
Post by modeltspaz » Thu May 06, 2021 5:31 pm
You're right Larry. That illustration does not show a 1914, it's a '15 for sure. You can clearly see the line drawing shows the top of the stamped sheet metal cowl used on the '15s.
However, since a dimensioned illustration such as this could not be found showing the wood firewall, slanted lower windshield on a '14, we used the dimensions from this illustration to install the top on John VonKavarly's 1914 Roadster.
We carefully measured the car and compared it to the illustration. We determined that the slanted lower half of the 1914 windshield gives the same setback to the upper half of the windshield as on a 1915 which uses a completely flat upper and lower winshield.
We installed the top, making sure not do any trimming or tacking of the top material at the front bow until we were positive that the top not only looked right, but fit right also.
Last Name: House
MTFCA Number: 115
Post by George House » Thu May 06, 2021 5:55 pm
The diagram shows 3 1/2” rear bow overhang behind the seat sheet metal. It’s correct. When I installed the top on my ‘14 runabout, I took great pains to make this ‘overhang’ 3”
I don’t know why I turned out this way. My parents were decent people.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri May 07, 2021 1:04 pm
I don't believe the rear bow's on roadsters use the wedge.
R Rathert
First Name: Rudy
Last Name: Rathert
* REQUIRED* Type and Year of Model Ts owned: 1909 1913 1914 1915 1926
Post by R Rathert » Sat May 08, 2021 6:41 am
Does anyone have the dimensions like this for a 1909 roadster? Rudy
R Rathert
First Name: Rudy
Last Name: Rathert
Post by R Rathert » Fri May 14, 2021 5:35 am
I must have asked a question that nobody knows the answer to, at least they are not telling me. O' well I will just do it my way and the critics will straighten me out. Rudy
Post by Scott_Conger » Fri May 14, 2021 9:20 am
Rudy
you asked a new question, about an entirely differently equipped car on someone else's topic.
Why on earth do you think someone opening a link with a question about a 1914 top is going to expect to find your request for info an a 1909?
Start a new topic and get your answer.
Here's a start: http://www.mtfca.com/discus/messages/17 ... 1320363549 and know that in 1909 there were variations that are typically undocumented or underdocumented.
NH Full Flow Float Valves
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri May 14, 2021 1:59 pm
I don't know if all 1914's had the same design as the 1913's, but I know the early 14's did. Both these photos were taken before I restored the car.
I also have a photo of the original top, but don't know how good it is.
13 Runabout 2.JPG (46.17 KiB) Viewed 2165 times
13 Runabout Top 1.JPG (45.92 KiB) Viewed 2165 times
