Removing the handbrake lever
Posted: Sun May 09, 2021 9:31 pm
by Corvette Guy
So, the pawl is rounded and doesn't engage the teeth on the quadrant on my 23 TT. It looks like the quadrant has been replaced but not the rest of it. It looks like there is a pin that holds the lever on the shaft and then once that is off I can work on replacing the pawl and it's pin. Should the pin on the lever just drive out or am I going to need to grind and/or use some heat?
Re: Removing the handbrake lever
Posted: Sun May 09, 2021 9:39 pm
by Rich Eagle
The pin goes through the brake handle and then is riveted over. You will need to grind it or make it smaller with vise grips or a chisel before pushing it back through. This discussion may help.
http://www.mtfca.com/discus/messages/59 ... 1451589535
Posted: Sun May 09, 2021 10:34 pm
by Corvette Guy
Rich,
I never thought about removing the whole assembly and working on it that way. Seems like it might be waaaaay easier to remove a couple of bolts. Thanks for the tip.
Posted: Sun May 09, 2021 11:29 pm
by ivaldes1
Remove the assembly and put it on an anvil or vise or other sturdy surface to hammer the pin out. It is very difficult to get the pin out without a hard surface to keep the hammer impact energy from dissipating where it should not be.
Posted: Mon May 10, 2021 10:46 am
Bench work job to replace worn pawl with new and new bearing rivet.
