Rebuilt Holley NH Installed, engine won’t start?
Its_Always_T_Time
First Name: Brendan
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 11:38 am
Now that I’ve got the starter gear fixed, I installed a rebuilt Holley NH carburetor as the Kingston L4 on the car was flooding quite badly and had a broken choke spring. I got the car to run with the new NH but it was running way to rich and the mixture control was doing nothing. I figured out that the pack nut on top was too tight and the needle was giving a false bottom. I removed the nut, screwed the needle all the way down and then replaced the nut but not too tight. I got the car to run for a short distance but it backfired and stalled at a red light. I richened the mixture a tad and that helped, but the engine still didn’t seem to be running as smooth as used to with the old Kingston before it started flooding. Today I tried starting Lizzie and the engine fired once and never fired again. The carb is getting gas, I don’t think it’s starving for fuel, I looked at the needle and it’s not scored, unfortunately I didn’t pull the plugs as I ran out of time and had to go to work. Not really sure what’s happening here. First it’s running too rich, then it runs too lean, now it doesn’t run at all. Very confused. :cry:
Edit: Might be having float level issues from what I can gather. I’ll check the level later today and see what it is.
The Little Ford Will Ramble Right Along!
22 Touring
Last Name: Gregush
MTFCA Number: 52564
Re: Rebuilt Holley NH Installed, engine won’t start?
Post by Mark Gregush » Tue May 11, 2021 12:01 pm
Is it a new new NH (as in rebuilt) or just new to you? Personally I would fix the Kingston over fill issue and go back to it. If it's not a rebuilt NH, you could also have plugged passages.
1920 Dodge touring
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue May 11, 2021 12:09 pm
Who's "rebuilt" NH did you install ? Not all "rebuilds" are created equal !!!
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 12:16 pm
I got it from a guy on EBay who sold other T parts, he seemed to have great ratings. I think I’ll fix the Kingston, only problem is the brass nut on the bottom is stuck and no matter how hard I try to remove it it just won’t budge.
Edit: I got the carb from this guy: https://www.ebay.com/usr/modelt96
22 Touring
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Tue May 11, 2021 12:22 pm
Did he claim it was rebuilt? Did you pay around $200. Did you buy a core?
Make sure the float isnt hanging up any where. Dont know the quality of the rebuild. were the idle passages cleaned? Steel needle & seat? Viatons can stick intermitently if not done rite.
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 12:39 pm
Yes the listing said it was restored and it came with an intake manifold to carb gasket. It was $185. I’ll check the idle passages and needles.
22 Touring
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Tue May 11, 2021 12:52 pm
Bottom the needle out (gently) then open 1 1/2 turns for initial start up setting. Also, ensure the intake manifold has a good seal to the block at both intake ports. Are you using paper gaskets or the steel ring and copper gland?
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 1:07 pm
I’m not sure what intake gaskets I have. I haven’t taken off the intake manifold off yet. I already have gently bottomed out the needle and backed it out 1-1.5 turns and she won’t start. :cry:
22 Touring
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue May 11, 2021 1:10 pm
Heat the nut up, even a propane torch should work and let cool, then try. May take several tries. Same with any of the jets. Regular gas outfit will work better. You can get the bodies orange and will not really hurt them. But in the case of the brass nut, don't want to get the area too hot, could melt the solder out of the float. :)
1920 Dodge touring
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Tue May 11, 2021 1:39 pm
NH -When you choke it, do it spit out extra gas?. If not, needle isnt opening to give you gas. Intermittent gas flow? Open drain valve & check for fuel.
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 1:45 pm
How do I make sure there’s no gas in the Kingston if the drain nut just spins without backing out?
22 Touring
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Tue May 11, 2021 1:54 pm
kingston. Pull the carb. shake it upside down to empty the gas. You will need to fix the drain when you get the bowl off. Using a torch is a bit dangerous on that stuck nut. Possibly dry it out as best you can & partially submerse it in a can of water, bowl side up whall heating. In water a small but hot oxy/acetelene flame to the nut. Water will protect the solder.
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Tue May 11, 2021 1:57 pm
Do you think soaking the bottom of the carb in Kroil or some other penetrating oil will hurt it? I might try that before messing with torches and gas vapors. :lol: :lol: :lol:
22 Touring
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Tue May 11, 2021 1:59 pm
Would not hurt. Not sure kroil will get thru the varnish. Worth a try.
Post by Scott_Conger » Tue May 11, 2021 2:15 pm
Usually, the very few times I thought I had a problem with something I bought from a reputable supplier, I worked the issue personally between the supplier and myself, not on a public forum. I have never had a problem go unsolved when dealt with thusly.
On a public forum, you will get advice ranging from appallingly bad to very good. Do you know which is which?
If you go back to the supplier, you will get advice and instructions that will, a: be accurate, and b: will very likely solve the problem, or if not, c: warrantee satisfaction.
I make my own carb parts and do not purchase someone else's service, so I cannot speak from experience as to the work you purchased but frankly have no reason to doubt that the job was adequately done. For anyone who's done more than 1, NH's are too simple to not do well and correctly, if that was their intent. That said, this supplier has a good reputation and has every reason and motivation to see that you're happy with his product.
Call him. Now.
NH Full Flow Float Valves
jeffstag
First Name: Jeff
Last Name: Versteeg
* REQUIRED* Type and Year of Model Ts owned: '27 TT, '25 TT, '23 Fordor, '23 Touring
Post by jeffstag » Tue May 11, 2021 2:38 pm
When you try and start with the NH, do you get gas into the bowl? Sometimes those little float valves stick, particularly if it's been replaced and hasn't been worked up and down much.
23 Touring
23 Fordor
25 TT
27 TT
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Tue May 11, 2021 2:53 pm
The 1 1/2 carb setting is a general setting and may not be the one that’s right for your T. Some T’s run their best at just a bit past 1 turn. My 21 runs the best at 1 1/4 turn or less but at 1 1/2 turn it won’t start when it’s cold.
Others have experienced the same thing one way or another.
It’s a good idea to call the rebuilder or at least email him about the issue. Until you know what exactly he did to the carb it’s a guessing game here on the forum. Deal with him first.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Tue May 11, 2021 3:38 pm
1 1/4 is the published starting point for a rebuilt carb. "will run rich" The extra 1/4 turn should not be enough to not start. The typical, final happy spot, setting is 1 to 1 1/8 turn.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue May 11, 2021 10:51 pm
If modelt96 is who I think it is, I'm sure the rebuild is legit. I would do as Scott suggests and contact him. He has a reputation as a straight shooter.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Wed May 12, 2021 7:17 am
Fuel Delivery or timing?
Vern (Vieux Carre)
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Wed May 12, 2021 3:12 pm
I have contacted the seller and I will be sending the carb back to be repaired. ModelT96 is a great seller. I didn’t know who they were at first but I found their website and phone number and contacted them and they seem very nice. 👍
22 Touring
Its_Always_T_Time
First Name: Brendan
MTFCA Number: 51106
Post by Its_Always_T_Time » Wed May 12, 2021 3:13 pm
Excuse please. :lol: :lol: :lol: :lol:
22 Touring
