Question re pulling a 27 engine
rgould1910
Last Name: Gould
Post by rgould1910 » Tue Mar 12, 2019 12:44 pm
Can a 27 engine/mag/trans assembly be removed from the front of the car without removing the trans cover? I am concerned the wider pedals won't exit the firewall with the trans cover in place.
Bill Robinson
First Name: Bill
Last Name: Robinson
MTFCA Number: 22487
MTFCI Number: 17887
Re: Question re pulling a 27 engine
Post by Bill Robinson » Tue Mar 12, 2019 1:05 pm
I have done it more times than I like on a ‘27 Tudor without removing the hogshead. Stick a rod in the front hand crank hole and lift the front of the motor which will tilt the back end down. The pedals will clear the firewall. Barely. Go slow, get a helper if possible, make sure all wires are out of the way.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Mar 12, 2019 1:12 pm
Yes. Just back off the brake band , low pedal fasteners and let them flop down some to easily clear the gas tank too. With a steep angle out the pedals will clear the cowl/firewall.
Scottio
Last Name: Lay
Post by Scottio » Tue Mar 12, 2019 1:14 pm
My wife and I have done the same thing on my 26 Roadster. Pulled the whole sh-bang at once. Be patient. Go slow and easy.
rgould1910
Last Name: Gould
Post by rgould1910 » Tue Mar 12, 2019 1:33 pm
Thank for the helpful replies!
Post by Norman Kling » Tue Mar 12, 2019 5:20 pm
Remove the steering column and radiator first Put a pulling eye in the second spark plug hole to raise the front of the engine. You can leave the crank in place. Just lift up and slide forward If the front is high enough, the pedals will pass through. You might need to move the front of the engine toward your right (the left side of the car) and the pedals will clear the firewall. It does help to move the pedals as Dan says, but can be done with them in the normal place.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Wed Mar 13, 2019 1:16 am
Yes, I have done it many many times without even playing with the pedal locations. As mentioned by others, very steep
Nose up angle, and with RHD drag the engine off centre so the pedals will clear.
Two points though... the 4th main will fall out and oil pour everywhere plus suggest you use some tin sheeting to protect the chassis and hood shelf from damage as you drag the engine out.
My Father has removed and refitted T Engines alone using a Block and Tackle tied to a tree Branch and lots of rope!
I have no idea how he managed it while working outside on a sandy front yard!
Alan
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Mar 13, 2019 8:15 am
Years ago someone mentioned using a defunct credit card under each pan ear so sliding the engine out would not scratch the paint but I have no idea if it works and never save old credit cards!
TFan
First Name: Jim
Last Name: Riedy
MTFCA Number: 25079
MTFCI Number: 18732
Post by TFan » Wed Mar 13, 2019 10:03 am
I save my used up gift cards and reuse them for spreading things like Bondo or JB weld they would work good for this purpose also. Jim
infotfordnl
First Name: Bert
Last Name: van Amstel
Post by infotfordnl » Wed Mar 13, 2019 6:52 pm
Just did this job today
Put the engine in
I did it by my own, engine out and in.
Pulling out dont forget to losen the trangel from the frontaxle, I forgot it when pulling out and had no cluw why the engine stickes in the frame, stupid me...
Hit my own head when I saw my mistake, beginners fault
Succes Bert
Nice movie of this Model T: https://youtu.be/jD1QJBZasdY
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Wed Mar 13, 2019 7:05 pm
Bert, What is a “trangel” ? I need translation!
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Wed Mar 13, 2019 7:20 pm
Radius Rod.
rgould1910
Last Name: Gould
Post by rgould1910 » Wed Mar 13, 2019 8:25 pm
Really nice looking car! A good tip about draining oil before pulling the engine. I probably would have forgot and had quite a mess to clean up.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Wed Mar 13, 2019 8:31 pm
I usually find that if I remove the starter, then I can just move the motor past the steering column. I use two spark plug hooks, one in #3 to initially move the motor mounts past the firewall and then one in #1 to lift it out. Drain the oil before you start😊😊
Tony Bowker
Ramona, California
1909 Touring, 1914 Touring, 1915 Speedster, 1924 Coupe.
infotfordnl
First Name: Bert
Post by infotfordnl » Thu Mar 14, 2019 3:59 am
Triangel
Maybe a bit dutch translation of the connection part frontaxle to the engine pan.
What is the correct word of this part??
Greets Bert
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Mar 14, 2019 6:47 am
In the U.S. it is generally called the front “radius rod”.
The slang term is “the wishbone”.
infotfordnl
First Name: Bert
Post by infotfordnl » Thu Mar 14, 2019 7:34 am
Thanks, still learning
:D
MichaelPawelek
First Name: Michael
Last Name: Pawelek
Post by MichaelPawelek » Thu Mar 14, 2019 9:16 am
Well, I am still learning also......every day! :)
