To Steve Jelf
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
To Steve Jelf
Post by BLB27 » Fri May 14, 2021 9:23 pm
Steve, See my 5-13 post under "Several Questions: About Hub Caps and Springs" . I asked you a question.
Thanks, Bruce BLB27
MTFCA Number: 16175
MTFCI Number: 14758
Re: To Steve Jelf
Post by Steve Jelf » Fri May 14, 2021 10:33 pm
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
Re: To Steve Jelf
Post by BLB27 » Fri May 14, 2021 11:34 pm
Thanks, Steve. One vendor has SLIP in a quart can. Another vendor has EZ-SLIDE in a quart but at half the price. I wonder if the material is the same. Do you know if a brush on material can be obtained in a smaller quantity? I would prefer to use a brush on, but maybe I will have to use an aerosol can.
Comments from anyone will be appreciated.
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Re: To Steve Jelf
Post by jiminbartow » Sat May 15, 2021 3:44 pm
Go back to your original hub cap, spring, post and open the link I posted. I believe EZ-Slide is discussed. Jim Patrick
