Gypsy Curtain Patterns for a 26-27 Roadster
Topic author - Posts: 205
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Does anyone have a pattern for the Gypsy Curtains for a 1926-27 Roadster?
I found some good pictures on this forum but not a pattern with dimensions.
- Last Name: Nunn
- MTFCA Number: 50321
Re: Gypsy Curtain Patterns for a 26-27 Roadster
...for me too, please.
- First Name: Danny
- Last Name: Deaton
If you can wait a couple weeks I have a set coming from Car. I would measure and post results unless someone beats me to it
Thanks for the offer. I will wait to hear from you.
Dennis
Dennis
- First Name: Danny
- Last Name: Deaton
Let me know if you need anything else. I don’t know much as I just got them and haven’t even held them up to the car yet.
Thanks for posting these pictures. I did not see these until this morning. Can you measure one of the angles?? I am very rusty on my geometry.
Dennis
Dennis
If you get the exact measurements of the inner triangle you can use this link to calculate the angles. Since the width of the each frame piece forms parallel lines the outer triangle would have the same angles. All the pictures with the tape measure need to be more accurate. https://www.calculator.net/triangle-cal ... &x=68&y=23DontKnowMuch wrote: ↑Mon May 31, 2021 11:48 amThanks for posting these pictures. I did not see these until this morning. Can you measure one of the angles?? I am very rusty on my geometry.
Dennis
Here is an example:
- First Name: Danny
- Last Name: Deaton
Make a template from cardboard first.
- First Name: Danny
- Last Name: Deaton
I will measure the angles as non are right angles to start with
