How to Remove Glass from Rear/Quarter Panel Windows
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
Post by BLB27 » Sun May 16, 2021 10:05 pm
I am in the process of removing the glass from the windows in my 1927 coupe. The photos show the windows. I have removed the hardened rubber on the inside of the rear window, but I haven't tried to "push" the glass out. I would appreciate any comments/suggestions on how to proceed.
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
Re: How to Remove Glass from Rear/Quarter Panel Windows
Post by BLB27 » Tue May 18, 2021 4:42 pm
I got the glass out of the three windows. Chipped the hardened rubber out on the inside and carefully pushed each out.
John Warren
Last Name: Warren
Post by John Warren » Wed May 19, 2021 1:28 am
Well now who is the expert! Thanks for sharing. :D
jiminbartow
Last Name: Patrick
MTFCA Number: 50126
Post by jiminbartow » Wed May 19, 2021 11:19 am
Just what I would have advised. Glad you figured it out on your own. Usually the most obvious solution is the correct one (see “Occam’s Razor”). The more experience you get in working on this beautiful T, the more confidence you will find, until the forum is the last resort. Good job. Keep it up. Jim Patrick
PS. New rubber is available from Snyder’s, Lang’s and the other suppliers.
