How to Remove Glass from Rear/Quarter Panel Windows
Posted: Sun May 16, 2021 10:05 pm
by BLB27
I am in the process of removing the glass from the windows in my 1927 coupe. The photos show the windows. I have removed the hardened rubber on the inside of the rear window, but I haven't tried to "push" the glass out. I would appreciate any comments/suggestions on how to proceed.
Re: How to Remove Glass from Rear/Quarter Panel Windows
Posted: Tue May 18, 2021 4:42 pm
by BLB27
I got the glass out of the three windows. Chipped the hardened rubber out on the inside and carefully pushed each out.
Posted: Wed May 19, 2021 1:28 am
by John Warren
Well now who is the expert! Thanks for sharing. :D
Posted: Wed May 19, 2021 11:19 am
by jiminbartow
Just what I would have advised. Glad you figured it out on your own. Usually the most obvious solution is the correct one (see “Occam’s Razor”). The more experience you get in working on this beautiful T, the more confidence you will find, until the forum is the last resort. Good job. Keep it up. Jim Patrick
PS. New rubber is available from Snyder’s, Lang’s and the other suppliers.
