Rust Removal inside the 1927 Coupe Body
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
The attached photo shows the floor under the seat inside my couple. It will be blasted cleaned. However, there are small seams near the front vertical part of the seat support. The blast cleaning will not remove rust in the seams. There are other small crevices at various places in the floor. I am thinking of putting some "Krud Kutter Must for Rust" in these seams and crevices and letting it soak and dry. Anybody see an problems with that procedure?
- First Name: dejaol
- Last Name: sone
Re: Rust Removal inside the 1927 Coupe Body
Take the time to enjoy the impossible quiz online
- MTFCA Number: 51486
Will it stop needless barking and controil most household pests for only 19.95 per month?/
- First Name: Bruce
- Last Name: Brakke
What are those two responses????????????
- MTFCA Number: 24868
- First Name: Bruce
- Last Name: Brakke
OH!! Thanks, What do think of my idea to put krud Kutter in the seams and crevices?
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Clean by vacuuming well, on a warm day, low humidity, give multiple light coats. Done!
Hope this Helps,
Hank
Hope this Helps,
Hank
- Last Name: Tannehill
- MTFCA Number: 49460
You could use a product called evaporust found at harbor freight Walmart and other like stores even on Amazon. I have used it with a small electric pump with a hose that sprays the liquid on the area and another hose for the pump to suck the liquid up. I used a large bucket to catch the sprayed evaporust that concentrated the liquid on the area that was rusty Worked like a charm in about 5 hours of me doing nothing but checking on the progress. I’ve also used it to clean out heads and blocks using the same technique, great product.
