Painting My 1927 Coupe Body
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
I plan on painting the main part of the body Channel Green or Highland Green. I have no idea how to proceed in obtaining the paint or what type of primer to use. Need Help! I will have an experienced body man paint it.
- First Name: Bob
- Last Name: McDaniel
- MTFCA Number: 28428
Re: Painting My 1927 Coupe Body
Each body man will use what he knows best so if you know who is going to paint it ask him first. I use PPG and always used epoxy primer over bare metal and body work. Then if you want to wet sand it you need another primer over that like high build. I stay away from anything in a rattle can because the reducers from the good stuff will cause problems with it most of the time. A good body man wont want to paint over someone elses primer without knowing what it is.
