Easy Way to Tell if 26 Touring has Floating Rear Hubs?
Posted: Tue May 18, 2021 10:44 am
by Mikey1968
I've ordered the disk brake kit and I need to let them know if I have the safety hubs or not. How can I tell if the prior owner installed them? I doubt it but thought I'd double check.
Thanks,
Mike
Re: Easy Way to Tell if 26 Touring has Floating Rear Hubs?
Posted: Tue May 18, 2021 10:49 am
by Philip
you should be able to see the locking screw i put mine inside the grease cup but i would pull
a wheel off that will tell you. philip
Posted: Tue May 18, 2021 10:56 am
What they look like. 2 styles unlikely that you have the "new" improved if any at all.. Might cause you to get the "New" improved
https://www.modeltford.com/pl.aspx?t=s& ... ubs&page=1
Posted: Tue May 18, 2021 11:39 am
by Oldav8tor
Wire wheels, wood wheels? It makes a difference. Regardless, the grease cups on the ends of the rear axle are used to hide the locking screw. If you're not sure, if you turn the grease cup out you'll see the aluminum surface of the hub if there is one.
Posted: Tue May 18, 2021 12:06 pm
by Mikey1968
Sorry, wire wheels. I downloaded the pdf on wire wheel safety hub installation from Texas Ts. Looks like I'm looking for a set bolt.
Thanks,
Mike
Posted: Tue May 18, 2021 12:37 pm
by Mikey1968
OK. All I found was a grease cup full of grease. Sooooo...no safety hubs as I expected.
Thanks for your help!
Mike
