Repurposing Model T Parts
Posted: Sun May 23, 2021 11:14 am
by TRDxB2
Some pictures are of Model T parts and other contain parts similar to T, so you can get the idea. The idea is to use worn disfunctional parts modified to work the idea. This link has has some really neat ideas
http://fordiyers.com/ways-to-repurpose-old-car-parts/
Old worn dull reflectors -
- reflector.png (622.79 KiB) Viewed 5986 times
could replace rivets with hook eyes for coats, hats , keys etc
Could used split rim tool , cam shaft
Re: Repurposing Model T Parts
Posted: Sun May 23, 2021 11:17 am
by TRDxB2
More ideas for them
- plugs.jpg (68.3 KiB) Viewed 5980 times
Posted: Sun May 23, 2021 11:19 am
by Mark Gregush
I have some 26 head lights that was thinking about adding socket and mounting plates to make outside wall lights. They are too far gone to use on cars but have nice patina for rustic look!
Posted: Sun May 23, 2021 11:34 am
by RajoRacer
I utilized some old T running boards for my accessory collection shelves - figured it was a fitting retirement place !
Posted: Sun May 23, 2021 11:35 am
by JohnM
Years ago my uncle used old model T driveshafts for horseshoe pegs.
Posted: Sun May 23, 2021 12:11 pm
by TRDxB2
And there's more
Posted: Sun May 23, 2021 12:15 pm
by TWrenn
Think I like the chandelier the most!
Posted: Sun May 23, 2021 6:11 pm
by DHort
the sink on the right. Is that for dipping parts in so they do not rust?
Lot of nice idea's out there. Like
Posted: Sun May 23, 2021 8:28 pm
by CraneJon
I once heard about a Montana Gunsmith who made damascus shotgun barrels out of Model T rear axles I asked Stan Howe about it and he did not know the gunsmith.
A local cider mill in Michigan has a press made from T Parts.
I have a friend who is making a pumping and operating windmill from T parts. Tower is four rails ot the frame.
Jon
Posted: Sun May 23, 2021 8:48 pm
by Mighty1924
Here is a couple of projects from T Parts
Lots of time last year too make things.
Posted: Wed May 26, 2021 6:18 pm
by Corey Walker
I went to help a friend put a 300 straight 6 to power an irrigation pump on this old trailer he had and it was obvious how it’s life began. It has the holes for the early running board brackets. His trailer for a welding machine is a T frame as well.
Posted: Wed May 26, 2021 7:56 pm
by ThreePedalTapDancer
- C76B4F63-0D84-41C5-BE1A-ADE4129F7BF7.jpeg (138.09 KiB) Viewed 5355 times
Posted: Wed May 26, 2021 8:11 pm
by TRDxB2
Forgot I did this. Old axle shaft used as an anvil for peening. Used on break lever cam & slow speed notch
Posted: Thu May 27, 2021 3:52 am
by Wayne Sheldon
Must be something wrong with me? I keep fixing parts others threw away and using them on my cars.
Posted: Thu May 27, 2021 7:42 am
by henryford2
Some of my work (
www.greenfancompany.com) Enjoy
- 7c31c5e0fb4d029dd20c6cf2e30a2d15.jpeg (19.3 KiB) Viewed 5189 times
- 8a8740f02f8bddd2e191d0014b7fc197.jpeg (35.61 KiB) Viewed 5189 times
- f4e1dbf12bc40b934848df70086a83fe.jpeg (36.78 KiB) Viewed 5189 times
Posted: Thu May 27, 2021 1:15 pm
by Dennis Fleming
Posted: Thu May 27, 2021 2:12 pm
by TRDxB2
Chassis engine stand (I didn't do the stand and had to give it back)
. Tilt front back to roll on wheels
Posted: Thu May 27, 2021 5:21 pm
by RustyFords
I'm about to make a cart for a gas welder out of a Model T frame. The frame was butchered in the past and is not suitable to be used for a car.
