Coil problem ?
Posted: Mon May 24, 2021 12:09 pm
by Will_Vanderburg
I have one coil that sparks on battery but that same coil does not spark when running on magneto. It makes ZERO difference when I place it in the box.
What say you?
Re: Coil problem ?
Posted: Mon May 24, 2021 12:14 pm
by dykker5502
Does it buzz on magnet?
Re: Coil problem ?
Posted: Mon May 24, 2021 1:44 pm
A magneto test might be in order. I'd think a weak coil would do better on Mag at anything above idle.
Re: Coil problem ?
Posted: Mon May 24, 2021 1:49 pm
by Will_Vanderburg
I recharged the mag yesterday
Re: Coil problem ?
Posted: Mon May 24, 2021 1:54 pm
If it buzzes and does not fire across at least a 1/8" gap, it most likely has internal problems. If it does not buzz, I'd look for point problems.
