Gas pump nozzle clip?
Posted: Wed May 26, 2021 3:48 pm
by KWTownsend
For those of you that live in areas with vapor recovery boot of gas pumps, you'll know what I am talking about.
I filled up one day and the guy handed me his "gas clip" out of his back pocket. It was made out of aluminum and it held back the boot that otherwide needs to be held with your hand while filling the gas tank. Otherwise it will shut off after you put about 2 gallons in...
I know motorcycle guys would appreciate one of these, too.
Anyone know where I can find one, or have dimensions so I can fabricate one?
Thanks,
Keith
Re: Gas pump nozzle clip?
Posted: Wed May 26, 2021 4:32 pm
That would be especially useful in filling a 26-27 or a Model A.
Posted: Wed May 26, 2021 4:58 pm
by George Mills
Posted: Wed May 26, 2021 5:23 pm
by KWTownsend
I already checked with them. They are out of stock until late June...
Posted: Wed May 26, 2021 8:58 pm
Should be easy to make
Found this : Nozzle size standard dictates that the delivery nozzles for unleaded fuel shall not exceed 0.85" in diameter while the delivery nozzles for leaded fuel shall not be less than 0.93" in diameter.. However if the bellows are and EVR type ( Enhanced Vapor Recovery) the pad needs rest flat enough to cause a suction.
Posted: Wed May 26, 2021 9:36 pm
by Novice
Should be a snap to build as many as You want with a 3-D printer.
Posted: Thu May 27, 2021 8:55 am
by TWrenn
Fab one from plexiglass or lexan. Can't be that hard to do.
Posted: Thu May 27, 2021 10:31 am
I've been using my left hand for years with no problems!
Posted: Thu May 27, 2021 10:34 am
by Kaiser
I think that is an inappropriate remark Larry, this is a family show :lol: :lol:
