Cut-down Touring Pickup - rear end rebuild thread
Posted: Tue Jun 01, 2021 10:34 pm
by Retro54
Had a good day getting started on the rebuild of my model T rear axle with dad. It goes under my soon to be on the road 1915 cut down touring roadster pickup. Using some of dad's home made jigs, this is his third axle rebuild and my first. I'm learning and he still is too. Trying to do it right guided by Mr. Chaffin's book.
Today was just a disassembly day. Good we took it apart. Babbitt thrust washers, a sheared off pin at the universal joint, a terrible axle end and other minor maladies were discovered and will be corrected prior to reassembly. Several times today we both said we'd never regularly drive a new to us T without going through the rear. Too many small issues that can be found and caught before they become bigger ones.
I'll update this thread as we go through the process. The axle will be completely refreshed mechanically to make it dependable and SAFE and left alone cosmetically. Thought folks would enjoy a thread like this with plenty of photos to ogle, and enjoy
Re: Cut-down Touring Pickup - rear end rebuild thread
Posted: Tue Jun 01, 2021 10:35 pm
by Retro54
Some more shots
by Retro54
Some more shots
Posted: Tue Jun 01, 2021 10:36 pm
by Retro54
Some more shots
Posted: Tue Jun 01, 2021 10:37 pm
by Retro54
Last shots until next time!
Posted: Tue Jun 01, 2021 10:40 pm
by Retro54
Forgot a shot of the terrible axle end! There should be threads all the way out... right? Haha.. a salvaged axle will replace this one.
Posted: Wed Jun 02, 2021 9:17 am
by Jack Putnam, in Ohio
The oil return springs on the axles can be installed by removing the outer bearing on the axle and sliding the spring onto the axle. It was not necessary to split the housings to install.
Posted: Wed Jun 02, 2021 2:54 pm
by Retro54
Good to know! We never installed any, so didn't know. The safety wire doesn't quite look like a nice tight Ford installation, so we are still leaning on this being apart once or so... of not, that Babbitt is like brand new for it to be 1915 oem.
Posted: Wed Jun 02, 2021 4:36 pm
by CudaMan
I wonder if the oil return springs will do anything if they are loose around the axle like the picture?
Posted: Wed Jun 02, 2021 6:00 pm
by Wayne Sheldon
That is what is commonly known as the 1913/'14 style rear end. They were actually used a bit longer than that. Many late 1912 models beginning about July of 1912 used that style, as did early 1915 cars. Both the earlier 1912/'15 rear ends like yours, and the later 1915/'16 rear ends were used randomly from the factory for the first few months of calendar year 1915. Years ago, original survivor cars built as late as June were sometimes seen with the earlier rear ends, however there was always some doubt that maybe the rear end had been changed at some time in its past. Back in the 1960s and '70s, most of the hobby felt a need to correct such "errors" and replaced what they perceived as anachronisms, even though in many cases they were originally manufactured that way. Because of that, a lot of those things mostly don't exist today.
I would suggest keeping it the way it was.
Original era photographs rarely show enough detail of the rear end to know which style the car had. In spite of that, I have seen a few era photographs showing the 1912/'15 rear end in early 1915 cars. If I can find one in the next several days (I have thousands of era photographs saved on my computer!)? I will try to post it here so you could have evidence to support your car as being correct. If I don't post it? I didn't find it (I lost nearly a thousand saved photos to a computer partial meltdown a few years ago).
Regardless how nice those 'Babbitt' washers look? DO NOT USE THEM! They were alright a hundred years ago. And if they did fail, at the speeds and on the roads of the day? One limped it home, no harm, no foul.
Unfortunately, the metals used in that 'Babbitt' mix, are seriously susceptible to chemical reactions over the years that have made the 'Babbitt" brittle. How brittle varies from one washer or rear end, to the next. There is no safe way to know if any one of them is marginally safe to use or not. So replacing them is the only right thing to do.
I put Babbitt in '--' because although the material is technically Babbitt, it is not the same Babbitt as used in a model T's bearings. And the reason "Babbitt" is capitalized, is that it was named after the fellow that invented the stuff back in the early/mid 1800s.
Posted: Wed Jun 02, 2021 9:07 pm
by Retro54
Wayne, thank you so much for the wisdom and info! Much appreciated. Yes, the Babbitt is being replaced, that is one of the main reasons for disassembly, although everything in the rear is getting disassembled and cleaned and inspected before reassembly.
This car is a January 1915 Beaudette touring. While the engine was replaced sometime before 1962, the remainder of the car does not show signs of being 'pieced together' and has enough of the 'right parts' for a car being assembled in the early part of the 1915 calendar year. That being said, it is a cut down touring and the back half of the car and rear fenders were long gone before I got it. I really, really appreciate your information on the rear axle in reference to 1915. Jibes with what I've read on Royce's website and other post regarding early model year 1915 cars.
I would really enjoy seeing the period photos and look forward to seeing one of you can find them. If you frequent Fall Hershey, you'll be able to see the car in the Chocolate field and I'd enjoy meeting you.
Andy
Posted: Thu Jun 03, 2021 1:05 am
The Canadians did the same thing, using up older parts in the assembly of later cars. I know of one 1915 original and intact tourer, now restored, which not only had the earlier back axle assembly, it also had the two piece riveted steering case on the steering column.
Posted: Thu Jun 03, 2021 4:46 am
by Wayne Sheldon
A January built body would be a very early 1915 open car. Bodies may or may not have sat at the factory for awhile, and most likely would have been assembled on a car by March at the latest assuming the body did not have production flaws that needed to be fixed. If I recall correctly from Royce (who has done serious research into the early 1915 models!), only about a thousand touring cars were assembled in January. So your car was likely a very early 1915 model touring car.
Allen, Quite a few USA early 1915 cars also had the riveted steering gear cases on them! Other odd things included the transition front fenders with four rivet brackets like earlier years, but the 1915 bill and beads. When I was getting started in this hobby, I met a lot of people with late 1914s that had early 1915 engines. Most of those were changed out to "correct an error" and replaced with 1914 or even 1913 engines. We now KNOW that the 1914 style runabouts and touring cars were being manufactured as late as April of 1915 and the early 1915 engines in those cars were likely correct from the factory.
A lot of early 1915s had the four rivet front fenders, most of those got replaced by the more common three rivet 1915/'16 fenders. Again, always said to "correct an error". Personally, I think a lot of honest history was destroyed by hobbyists a half century ago. I do hope people are learning to do better?
I looked through a few hundred photos so far, and found this one.
From the look of the curves transitioning from the 'pumpkin' to the tubes, I am fairly sure this early 1915 chassis has the 1912/'15 twelve rivet rear end.
It looks to have the later one-piece steering gear case.
Posted: Thu Jun 03, 2021 4:57 am
by Wayne Sheldon
I zoomed in as close as the picture would allow. While the modern digital world offers a great deal of information with just a few computer clicks, digitized images often loose considerable detail if they are not handled with extreme levels of resolution data. I have seen glass plate photos digitized on sites like Shorpy that one can see scratches in a single brick in a building across the street! Too many photos when zoomed in close have lost way too much detail in the digitization process. I suspect the original prints of this photo had considerable more detail in them.
Not likely I will ever get to Hershey. Too far for me with my limited budgets.
Posted: Thu Jun 03, 2021 5:17 am
by Wayne Sheldon
Found another one! Might not be quite the definitive example (which would be an open car early 1915?)? It is an early 1915 couplet, but clearly has the twelve rivet rear end. Being a couplet, it could have been manufactured as early as October of 1914, so use of the earlier rear end may not have been unusual.
Posted: Thu Jun 03, 2021 6:53 am
by Retro54
Awesome info Wayne, thank you. I totally understand about Hershey. I've lived 15 minutes away my entire life, so I'm spoiled.
Sharing info like this is what makes the hobby fun. I'll have to examine your photos closer on the laptop. Thank you very much for taking the time to look through your stash. Here is a shot of my front. Fenders have the 4 rivet brackets. I can't wait to get this car on the road, it'll be fun!
Posted: Sat Jun 19, 2021 7:29 pm
by Retro54
Got back to the home garage on Friday and spent a relaxing afternoon with Dad, taking the last of the rear axle apart, organizing parts, and checking some against tolerances to see if they need replacing. Sure is coming along ! Dad has been working steadily cleaning things up between the last time out, which helps me out a lot staying on track with getting this back together. Not much more cleaning to do, soon it is time for reassembly! I'll post some photos in a few minutes showing the progress. Not too much to see, but everyone likes pictures right??
Andy
Posted: Sat Jun 19, 2021 8:12 pm
by Dallas Landers
Right!!!!!
Posted: Sat Jun 19, 2021 9:01 pm
by Retro54
More pictures! That took more than a few minutes!
Posted: Sat Jun 19, 2021 9:03 pm
by Retro54
The car... awaiting the rebuilt rear axle and new rubber!
Posted: Mon Jul 05, 2021 7:32 pm
by Retro54
Got out to dads garage July 3rd and got the new wear parts installed in the the driveshaft and the driveshaft ready to go back in the car. Next time will be the rear axle and housings. Getting there!
Posted: Mon Jul 05, 2021 7:34 pm
by Retro54
Some more shots!
Posted: Mon Jul 05, 2021 8:13 pm
Drive shaft pix shows 1 washer. Should be 3 pieces. 2 thrust washers & a caged ball bearing between.
Posted: Mon Jul 05, 2021 9:22 pm
by Retro54
We prefer cage-less free range ball bearings. More natural that way.
Posted: Mon Jul 05, 2021 10:09 pm
Love to see a pix of it. Is that something you came across thru a T vender or your research?
Posted: Tue Jul 06, 2021 6:51 am
by Retro54
You didn't catch my joke... on these earlier ones there are two 'race washers' and 15 free floating ball bearings. Not shown in the photos to protect the innocent.
Posted: Tue Jul 06, 2021 8:10 am
That explains it. I see that now. I dont use this type too often. Thanks.
Posted: Sun Aug 08, 2021 9:42 pm
by Retro54
Some more updates from the last few weeks of Re-assembling the 1915 era rear axle for the RPU. Gonna be a big photo dump, as it's in the truck now.
Posted: Sun Aug 08, 2021 9:45 pm
by Retro54
Next steps in our process!
Posted: Sun Aug 08, 2021 9:48 pm
by Retro54
Next Steps in our process... we are not cigar smokers.. but a neighbor is! The boxes make great parts storage units for parts such as those on the rear axle. Each box is a different sub-assembly and different side of the axle.
Posted: Sun Aug 08, 2021 9:52 pm
by Retro54
And yet another set of pics!
Posted: Sun Aug 08, 2021 9:56 pm
by Retro54
And yet another set of photos... these rear ends are a lot of work! haha
Posted: Sun Aug 08, 2021 10:03 pm
by Retro54
Now to get this thing in the car. My brother (Also a member of the message board) has a Weaver Twin Auto jack. He lent it to the project and that's what we used to install and un install the axle. What a life saver! Such a simple tool makes installation much easier! Now the next step is to paint my freshly sandblasted and primed rims, retrofit the new rubber stem tubes with old metal schraders, and mount the Universal T Drivers and then learn to drive the darn thing! haha. I can't wait. Hope people enjoyed looking at all the photos. My father and I are not anywhere near experts, but with this being his third rear he's rebuilt, we keep learning a bit each time (Mostly from manuals and other users on this board). Cheers!
Posted: Sun Aug 08, 2021 10:36 pm
Thank you for the photo sequence. It really helps augment the written instructions.
I am about to tackle the similar, ' 26 axle with the Adjustable Pinion assembly..
Posted: Sun Aug 08, 2021 10:53 pm
by Retro54
You're welcome for sure! We certainly follow the book too. But I'm a visual guy too... Who doesn't like photos? Haha. I think the parts themselves are fun to look at. Good luck with the big drum. My brother, DanB posted a similar thread when he rebuilt his large drum ruxtle with Dad last year.
Posted: Sun Aug 08, 2021 11:13 pm
Envious of your being able to work with your dad. My dad is 2400 miles away and we don't visit often these days :cry:
Enjoy these moments while you can.
