T Running Sluggish
Posted: Wed Jun 02, 2021 7:01 am
by JB007
Just got the T out for the season,( in storage since October of 2020 ) This year I ended up changing the sediment bulb on the gas tank, changed the oil, charged the battery cleaned her and dusted her off. Car started right up. However when driving down the road she seems to run very sluggish, not a lot of power almost as if something is holding her back from running properly. When I put her away for the Winter last year she was running real well. Novice T owner looking for possible solution or thoughts
Thank you
John
Re: T Running Sluggish
Posted: Wed Jun 02, 2021 8:12 am
New sediment bowl. Is it fully open? Valve hole in maximum flow with handle position? Old gas?
Posted: Wed Jun 02, 2021 9:01 am
Was your gas tank at least half full or so? Good flow of gas? How about carb adjustment. When you start it up and idling does it seem sluggish when revving the engine? Is it missing or just slow getting to speed? Clean up the timer?
Sounds to me like it’s a gas flow issue without knowing more.
Posted: Wed Jun 02, 2021 9:26 am
I'd check for emergency brake drag, exhaust obstruction (mice, dirt daubers) drain the carburetor bowl into a clean container, then, with carburetor drain open, turn on gas cock and check for for good fuel flow and any evidence of dirt. Beyond that, timer, plugs, and points... maybe too much oil in pan?
Posted: Wed Jun 02, 2021 3:21 pm
by ModelT46
Timer setting. It maybe to much retarded.
Posted: Wed Jun 02, 2021 3:43 pm
by got10carz
Mouse nest in muffler? They usually blow out.
