To weld or not to weld.........
Posted: Wed Mar 13, 2019 10:21 pm
........that is the question!
Now that my engine rebuild is almost complete, it's time to think about a speedster frame. My plan for lowering it (around 5") is to use a square tube front cross member that will enclose the spring at frame rail height. The rear will be two simple brackets that will lower the rails an equal amount. Now the question....
What is the general opinion about welding on the T frame? There seems to be two separate camps of thought on this, one of which saying that the heat will destroy the "special steel". The other side says no harm will be done.
I don't see why modern welding will harm anything. Henry's steel was probably quite good, but I'll be those rails were pressed cold and all holes punched. If anything, welding heat might soften (anneal) the steel a bit but it's certainly not like heating a treated material such as a knife blade. On top of that we've seen many trailers, etc. welded up with no ill effects.
So, will welding do any harm?
