So pulling the rear wheels and re-examining the drums/brake linings I could smell gas. Noted the sediment bowl petcock had a small drip and I usually flush this monthly and did not get much out of it when I tried.
I had a replacement petcock and will get that in as the other one was plugged up. Yes when I cleaned out the tank I removed the worn out bowl screen and will install the internal filter 2903BSC offered by Langs as well.
Flushed and checked my NH bowl that was nice and clean.
one thing leads to another, in a good way
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: one thing leads to another, in a good way
FYI - white Teflon tape is not compatible with gasoline - some will state that yellow tape is for gas which is true BUT for natural gas or propane - do yourself a favor & get some reputable fuel sealer.
Topic author - Posts: 209
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
- MTFCA Number: 32419
Thanks Steve, that's just one wrap around those threads for any variation between the male petcock/female sediment bowl threads.
I have been using Gasoila for many years, enjoy your summer.
