More '13 'Issues'
Posted: Mon Jun 14, 2021 6:27 pm
				I'm driving this '13 T around, getting a feel for it's bad habits that I need to address...  The Only other T I Drive is Dads '24 TT that he set up Beautifully. I've been driving it about Twice a week for 8 Years. Short Town Trips, as well as Multi Hour Drives..
This '13 T belongs to someone else and I volunteered to make it behave better, after another person did major work on it.. Pistons, Bearings, Bands, and new Safety Wire on the Clutch Pack.. No Idea what was done in there.. It needs Tripple Gear Bearings BAD! They had the Flywheel off, as it's now a Ring Gear Flywheel, and the Mag Coils have a 'Factory' Starter Notch in the Housing. And the Hogs Head was replaced as well. Running Starter at 6 Volt. I added the Mag Charger, and an E Timer, with an External Hogs Head oil Line.
I've been adjusting the Bands to get the Peddle Free Play as good as I think it should be, and the Main Clutch is not Dragging on the Hand Brake Slide. I drive this T without the Floorboards, or the Hood, so I can see/smell/hear anything important.
The Main Clutch will 'Slip' if you do not take ALL the Throttle out of it when Letting up the Direct Peddle. Is this a Normal T Function, that my '24 TT does not have because of the Jackrabbit Clutch dad put into it? If not, then is it an Oil/Treatment/Change that will work better?
I rebuilt the NH Carb with a Bunch of new parts ( Bushed the Body for New Throttle and Choke Shaft,Viton Needle on a new seat as well).. I Set the Float Seam to Level at Shutoff. The Engine tends to run Lean at Idle.. This is a Senario that was with the Carb before Re-Bushing and adding new T-Shaft. I was hoping the Lean at Idle was a function of the T-Shaft Air Leak.. The Symptiom is better, but not 'Fixed'.
Is there an 'Idle Mixture Adjustment' Technique.. I'd think it'd be raising the Float Level, and Closing the Main Jet, but I'd rather not start tweeking things when the Information is Out there.. I'm a Idiot, but I'm not Foolish..
Thanks for your Help..
Cap
Cap
